7i96 Configuration Tool Deb
- persei8
- Thank you received: 131
14 Feb 2021 05:22 #198777
by persei8
7i96 Configuration Tool Deb was created by persei8
I've had this discussion before, but never got a clear answer. What do I have to do to get the RS485 pins to work as a serial port for modbus? (TB2 pins 16 to 19) I'm thinking the 7i96 needs to be reflashed but where do I get the bit file?
- Thank you received: 4628
18 Feb 2021 11:30 #199236
Replied by andypugh on topic 7i96 Configuration Tool Deb
You would need a bitfile that puts a UART module in the place of the smart-serial module.
But that is only part of the problem, as you then need a Modbus _hal_ driver to access the UART, it won't appear in /dev like a normal userspace UART.
- persei8
18 Feb 2021 14:10 #199253
by persei8
Replied by persei8 on topic 7i96 Configuration Tool Deb
I have a modbus hal driver that I wrote for a usb to modbus dongle that appears as /dev/ttyUSB0. I'm happy to share it with anyone who wants it. The problem is getting someone to tell me where to get the bitfile. I'm hoping one already exists as I don't have the tools required to make one.
- Thank you received: 5220
18 Feb 2021 15:07 #199263
Replied by PCW on topic 7i96 Configuration Tool Deb
I would think the most flexible way to do this would be to use PacketUART
firmware and build a driver for that using Curtis Duttons HAL_Port or similar
interface so you have real time access to a UART via hal pins.
This make the UART interface protocol agnostic.
Then a Modbus protocol component with a HAL_Port interface would be created
(possible just adapting existing Modbus code)
Unfortunately HAL_Port is missing any example code
- persei8
18 Feb 2021 15:58 #199279
by persei8
In this link -> 162.243.45.186/27-driver-boards/34602-se...the-mesa-7i96#155216 you cited a couple files. My simple question is : where are they?
- Kost
24 Feb 2021 09:15 - 24 Feb 2021 09:16 #199947
by Kost
Replied by Kost on topic 7i96 Configuration Tool Deb
persei8, as i know, all prebuilt bitfiles for supported configurations is placed on mesanet site
www.mesanet.com/software/parallel/7i96.zip
Bitfile for uart configuration is included. Very intrested about your work, i think about the same, using a built-in rs485 for vfd is a very good option.
Last edit: 24 Feb 2021 09:16 by Kost.
The following user(s) said Thank You: persei8
- persei8
24 Feb 2021 16:44 #200001
by persei8
Thank you! The mesanet.com home page has no links to software. This was the missing info I needed.
- BigJohnT
- Thank you received: 994
27 Feb 2021 00:10 #200261
by BigJohnT
Replied by BigJohnT on topic 7i96 Configuration Tool Deb
You should go to mesaus.com ...
JT
JT
02 Mar 2021 21:57 #200834
store.mesanet.com has the software links for each card hidden in the "specifications" tab.
I don't know why they are there. It isn't an obvious place to look.
Time to create page: 0.341 seconds
