General CNC control to LInuxcnc config
- dansawyer
22 Feb 2021 20:10 #199760
by dansawyer
General CNC control to LInuxcnc config was created by dansawyer
I am a newbe to linuxcnc and CNC in general; gut I have a fair software and electronics background. I came about a partially completed Bridgeport BOSS 5 upgrade with PC, parallel connect to a PICA board, Gecko drivers, and steppers in place.
I have the live CD version of Linuxcnc running in a VM. I can work through the stepper wizard and find what looks like the right path for Gecko config, but I do not see any way to configure the PICA board from that wizard. Conversely from the pins wizard I see a configure for MESA (not PICA).
My questions are what is the right path to configure linuxcnc for a PC, a PICA board, and Geiko drivers? Is there a wizard, if so which one? Where are the PICA pins configured?
I apologize for the basic question but I am stuck on which path to start down. Thank you in advance. Dan
- Thank you received: 1476
22 Feb 2021 21:14 #199768
Replied by Todd Zuercher on topic General CNC control to LInuxcnc config
First of all Linuxcnc can't control hardware from a virtual machine (mostly because real-time does not work there, but also can't really connect to physical hardware.)
Second, I don't think a PICA board can be supported, that would be a GRBL thing. (Unless it can be plugged into and used with an ordinary parallel port like a breakout board.)
- dansawyer
22 Feb 2021 23:01 #199781
by dansawyer
Replied by dansawyer on topic General CNC control to LInuxcnc config
Thank you. Yes, I am not trying to operate linuxcnc from a virtual machine, only experimenting with becoming familuar with the tool. It was a dry run to learn about general configuration.
The PICA board is listed as part of supported hardware. I thought its visibility to linuxcnc would be limited to the pin layout of the Geiko connections? Is this an invalid assumption?
- Thank you received: 7485
22 Feb 2021 23:13 #199783
Replied by tommylight on topic General CNC control to LInuxcnc config
Not PICA,
PICO boards are supported by LinuxCNC, and the owner is a very helpful member of this forum that goes above and beyond to help users of those boards.
- dansawyer
23 Feb 2021 01:31 #199790
by dansawyer
You are correct, it is a PICO universal stepper. It is connected to the PC via a parallel port and to the Geico drivers. Is this hardware configuration supported by the stepper wizard? Where can I find a 'how to' to configure the PICO board hardware setup in linuxcnc?
Thanks again, Dan
Thanks again, Dan
- dansawyer
23 Feb 2021 03:26 #199794
by dansawyer
Progress, a search of the Pico documentation found a wireing diagram:
pico-systems.com/images/uscgecko.pdf
This documents how the pico board is set up to connect to Geiko drivers. I assume that the mapping from the wiring pins is reflected in the parallel port configuration page.
Thanks for the pointers. Dan
28 Feb 2021 02:02 #200365
Replied by andypugh on topic General CNC control to LInuxcnc config
I have moved this post into "Driver Boards" where there is a good chance that the Pico chap will see it.
28 Feb 2021 10:37 #200386
Was wondering that i read this before...I have moved this post into "Driver Boards" where there is a good chance that the Pico chap will see it.
- jmelson
- Thank you received: 126
28 Feb 2021 15:53 #200428
by jmelson
No, the stepconfig wizard is for Mesa boards, not Pico. We do have sample configs under "by interface/pico/univstep"
that can be used as a starting place for your particular setup.
Here's a link to a wiki description of the hardware : wiki.linuxcnc.org/cgi-bin/wiki.pl?Universal_Stepper_Controller
And, a general article on first-time startup:
forum.linuxcnc.org/27-driver-boards/14977-pico-systems-faq
Note: this has sections on all 3 of our product lines, you want to concentrate on the part for the universal steppper controller.
The USC is not a breakout board, it is a step generator and encoder counter. The encoder counter can either count real encoder position or count the steps issued to a step driver for open-loop operation. The selection is made for each axis with a DIP switch. See :
pico-systems.com/univstep.html
for more info on switches and connectors.
And, if more questions arise, certainly contact me directly or here on the forum.
Jon
Replied by jmelson on topic General CNC control to LInuxcnc config
Sorry, I did not see this thread until Andy alerted me.You are correct, it is a PICO universal stepper. It is connected to the PC via a parallel port and to the Geico drivers. Is this hardware configuration supported by the stepper wizard? Where can I find a 'how to' to configure the PICO board hardware setup in linuxcnc?
Thanks again, Dan
Jon
- jmelson
01 Mar 2021 23:21 #200749
by jmelson
Jon
No. The parallel port is used as a communication port to the stepper controller FPGA. There is no 1:1 correspondence between the parallel port pins and the step outputs or digital I/O. Do not pay any attention to the parallel port setup, that is used for software generated stepping. The USC board provides hardware step generation.Progress, a search of the Pico documentation found a wireing diagram:
Jon
Time to create page: 0.309 seconds
