Mesa card loading error
- robh
- Thank you received: 22
28 Feb 2021 16:56 #200436
by robh
Mesa card loading error was created by robh
Hi
running a
6I24-25
with
7i48 in port4
7i44 in port 1
flashed the card with 5i24_25_svss6_8.bit
in the ini i have
[HOSTMOT2]
DRIVER=hm2_pci
BOARD=5i24
CONFIG="firmware=hm2/5i24/5i24_25_svss6_8.bit num_encoders=6 num_pwmgens=6 num_stepgens=0"
in hal
loadrt [HOSTMOT2](DRIVER) config=[HOSTMOT2](CONFIG)
setp hm2_[HOSTMOT2](BOARD).0.pwmgen.pwm_frequency 24000
setp hm2_[HOSTMOT2](BOARD).0.pwmgen.pdm_frequency 6000000
setp hm2_[HOSTMOT2](BOARD).0.watchdog.timeout_ns 10000000
on start up i get
Note: Using POSIX realtime
hm2/hm2_5i24.0: inconsistent Module Descriptor for LED, not loading driver
hm2/hm2_5i24.0: Version = 0, expected 0
hm2/hm2_5i24.0: NumRegisters = 1, expected 1
hm2/hm2_5i24.0: InstanceStride = 0x00000004, expected 0x00000004
hm2/hm2_5i24.0: MultipleRegisters = 0x0000FFFF, expected 0x00000000
hm2/hm2_5i24.0: inconsistent Module Descriptor!
hm2/hm2_5i24.0: failed to parse Module Descriptor 6
hm2_5i24.0: board fails HM2 registration
RTAPI_PCI: Unmapped 65536 bytes at 0x7fd0f59ff000
Driver probe function failed!
hm2_pci: error registering PCI driver
hm2_pci: rtapi_app_main: Operation not permitted (-1)
./dsg.hal:18: waitpid failed /usr/bin/rtapi_app hm2_pci
./dsg.hal:18: /usr/bin/rtapi_app exited without becoming ready
./dsg.hal:18: insmod for hm2_pci failed, returned -1
5656
Stopping realtime threads
Unloading hal components
running a
6I24-25
with
7i48 in port4
7i44 in port 1
in the ini i have
[HOSTMOT2]
DRIVER=hm2_pci
BOARD=5i24
in hal
on start up i get
5656
- Thank you received: 5289
28 Feb 2021 17:32 #200443
Replied by PCW on topic Mesa card loading error
That actually looks more like a data error rather than a firmware error
Is the 6I24 jumpered for a 33 MHz PCI clock (the 5I24 firmware requires this)
- robh
28 Feb 2021 22:41 #200476
by robh
Replied by robh on topic Mesa card loading error
it was the W2 jumper , set it to the up position and all was ok then, up and running
thanks
thanks
Time to create page: 0.238 seconds
