Rpi 400, 7c85 to 7185s setup? xylotex
- 1RandomSquirrel
05 Mar 2021 21:30 #201133
by 1RandomSquirrel
Replied by 1RandomSquirrel on topic Rpi 400, 7c85 to 7185s setup? xylotex
Thanks on those pins.
The db25 pins you added to master is that in the buildbot 2.9 and 2.8?
- Thank you received: 5325
05 Mar 2021 21:53 #201134
Replied by PCW on topic Rpi 400, 7c85 to 7185s setup? xylotex
Just 2.9
- 1RandomSquirrel
06 Mar 2021 12:37 - 06 Mar 2021 13:44 #201180
by 1RandomSquirrel
I am making progress. When i start linuxcnc the driver makes a noise change! I am so happy!
Now i am getting hm2/hm2_7c81.0: Watchdog has bit! (set the .has-bit pin to False to resume)
I'm not sure if i have the right kernel for some reason i thought the when i did cat /proc/version it would say realtime but maybe that way because of rtai and now i should be running preempt
pi@raspberrypi:~ $ cat /proc/version
Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
pi@raspberrypi:~ $ linuxcnc -d
Debug mode on
+ getopts dvlhkr opt
+ shift 1
+ case "" in
+ '[' -z ']'
+ tty -s
+ trap ErrorCheck EXIT
+ '[' '!' -z '' ']'
+ EXTRA_ARGS=
+ RUN_IN_PLACE=no
+ echo RUN_IN_PLACE=no
+ LINUXCNCVERSION=2.9.0-pre0-3640-g8be0ba545
+ export LINUXCNCVERSION
+ INIVAR=inivar
+ HALCMD='halcmd '
+ PICKCONFIG='/usr/bin/wish8.6 /usr/lib/tcltk/linuxcnc/bin/pickconfig.tcl'
+ LINUXCNC_EMCSH=/usr/bin/wish8.6
+ echo LINUXCNC_DIR=
+ echo LINUXCNC_BIN_DIR=/usr/bin
+ echo LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
+ echo LINUXCNC_SCRIPT_DIR=
+ echo LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules
+ echo LINUXCNC_CONFIG_DIR=
+ echo LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs
+ echo INIVAR=inivar
+ echo HALCMD=halcmd
+ echo LINUXCNC_EMCSH=/usr/bin/wish8.6
+ export LINUXCNC_TCL_DIR
+ export LINUXCNC_EMCSH
+ export LINUXCNC_HELP_DIR
+ export LINUXCNC_LANG_DIR
+ export REALTIME
+ export HALCMD
+ export LINUXCNC_NCFILES_DIR
+ '[' -z ']'
+ echo 'LINUXCNC - 2.9.0-pre0-3640-g8be0ba545'
+ '[' '!' -z '' ']'
+ '[' '!' -n '' ']'
++ /usr/bin/wish8.6 /usr/lib/tcltk/linuxcnc/bin/pickconfig.tcl
+ INIFILE=/home/pi/linuxcnc/configs/Lathe/Lathe.ini
+ '[' /home/pi/linuxcnc/configs/Lathe/Lathe.ini.demo = /home/pi/linuxcnc/configs/Lathe/Lathe.ini ']'
+ '[' '!' -n /home/pi/linuxcnc/configs/Lathe/Lathe.ini ']'
++ handle_includes /home/pi/linuxcnc/configs/Lathe/Lathe.ini
++ hdr='# handle_includes():'
++ inifile=/home/pi/linuxcnc/configs/Lathe/Lathe.ini
+++ dirname /home/pi/linuxcnc/configs/Lathe/Lathe.ini
++ cd /home/pi/linuxcnc/configs/Lathe
++ /bin/grep '^#INCLUDE' /home/pi/linuxcnc/configs/Lathe/Lathe.ini
++ status=1
++ '[' 1 -ne 0 ']'
++ echo /home/pi/linuxcnc/configs/Lathe/Lathe.ini
++ return 0
+ INI_NAME=Lathe.ini
+ INI_DIR=/home/pi/linuxcnc/configs/Lathe
+ CONFIG_DIR=/home/pi/linuxcnc/configs/Lathe
+ export CONFIG_DIR
+ export PATH=/home/pi/linuxcnc/configs/Lathe/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
+ PATH=/home/pi/linuxcnc/configs/Lathe/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
+ '[' -z ']'
+ echo 'Machine configuration directory is '\''/home/pi/linuxcnc/configs/Lathe'\'''
Machine configuration directory is '/home/pi/linuxcnc/configs/Lathe'
+ echo 'Machine configuration file is '\''Lathe.ini'\'''
Machine configuration file is 'Lathe.ini'
+ '[' '!' -f /home/pi/linuxcnc/configs/Lathe/Lathe.ini ']'
+ echo INIFILE=/home/pi/linuxcnc/configs/Lathe/Lathe.ini
+ retval=
+ GetFromIni VERSION EMC
+ name=VERSION
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var VERSION -sec EMC
+ retval=1.1
+ '[' '!' -n VERSION ']'
+ echo VERSION=1.1
+ '[' 1.1 '!=' 1.1 ']'
+ /usr/bin/tclsh8.6 /usr/share/linuxcnc/hallib/check_config.tcl /home/pi/linuxcnc/configs/Lathe/Lathe.ini
+ exitval=0
+ case "$exitval" in
+ GetFromIni PARAMETER_FILE RS274NGC
+ name=PARAMETER_FILE
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var PARAMETER_FILE -sec RS274NGC
+ retval=linuxcnc.var
+ '[' '!' -n PARAMETER_FILE ']'
+ echo PARAMETER_FILE=linuxcnc.var
+ RS274NGC_PARAMFILE=linuxcnc.var
+ GetFromIniEx MOT MOT EMCMOT EMCMOT motmod
+ original_var='[MOT]MOT'
+ '[' 5 -ge 2 ']'
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var MOT -sec MOT
+ retval=
+ shift 2
+ '[' 3 -ge 2 ']'
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var EMCMOT -sec EMCMOT
+ retval=motmod
+ return
+ EMCMOT=motmod.so
+ GetFromIniEx IO IO EMCIO EMCIO io
+ original_var='[IO]IO'
+ '[' 5 -ge 2 ']'
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var IO -sec IO
+ retval=
+ shift 2
+ '[' 3 -ge 2 ']'
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var EMCIO -sec EMCIO
+ retval=io
+ return
+ EMCIO=io
+ GetFromIni TASK TASK
+ name=TASK
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var TASK -sec TASK
+ retval=milltask
+ '[' '!' -n TASK ']'
+ echo TASK=milltask
+ EMCTASK=milltask
+ '[' milltask = emctask ']'
+ EMCSERVER=linuxcncsvr
+ GetFromIniQuiet HALUI HAL
+ name=HALUI
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var HALUI -sec HAL
+ retval=halui
+ '[' '!' -n HALUI ']'
+ echo HALUI=halui
+ HALUI=halui
+ GetFromIni DISPLAY DISPLAY
+ name=DISPLAY
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var DISPLAY -sec DISPLAY
+ retval=axis
+ '[' '!' -n DISPLAY ']'
+ echo DISPLAY=axis
++ set -- axis
++ echo axis
+ EMCDISPLAY=axis
++ set -- axis
++ shift
++ echo
+ EMCDISPLAYARGS=
+ case $EMCDISPLAY in
+ GetFromIniEx NML_FILE LINUXCNC NML_FILE EMC /usr/share/linuxcnc/linuxcnc.nml
+ original_var='[LINUXCNC]NML_FILE'
+ '[' 5 -ge 2 ']'
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var NML_FILE -sec LINUXCNC
+ retval=
+ shift 2
+ '[' 3 -ge 2 ']'
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var NML_FILE -sec EMC
+ retval=
+ shift 2
+ '[' 1 -ge 2 ']'
+ '[' 1 -eq 0 ']'
+ retval=/usr/share/linuxcnc/linuxcnc.nml
+ NMLFILE=/usr/share/linuxcnc/linuxcnc.nml
+ export NMLFILE
+ GetFromIni COORDINATES TRAJ
+ name=COORDINATES
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var COORDINATES -sec TRAJ
+ retval=XZ
+ '[' '!' -n COORDINATES ']'
+ echo COORDINATES=XZ
+ TRAJ_COORDINATES=XZ
+ export TRAJ_COORDINATES
+ GetFromIni KINEMATICS KINS
+ name=KINEMATICS
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var KINEMATICS -sec KINS
+ retval='trivkins coordinates=XZ'
+ '[' '!' -n KINEMATICS ']'
+ echo 'KINEMATICS=trivkins coordinates=XZ'
+ KINS_KINEMATICS='trivkins coordinates=XZ'
+ export KINS_KINEMATICS
+ KILL_TASK=
+ KILL_TIMEOUT=20
+ LOCKFILE=/tmp/linuxcnc.lock
+ '[' -f /tmp/linuxcnc.lock ']'
+ echo Starting LinuxCNC...
+ trap 'Cleanup ; exit 0' SIGINT SIGTERM
+ touch /tmp/linuxcnc.lock
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var INTRO_GRAPHIC -sec DISPLAY
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var INTRO_TIME -sec DISPLAY
+ imgtime=5
+ '[' 5 = '' ']'
+ '[' linuxcnc.gif '!=' '' ']'
+ '[' -e linuxcnc.gif ']'
+ '[' -e /home/pi/linuxcnc/configs/Lathe/linuxcnc.gif ']'
+ '[' -e /usr/share/linuxcnc/linuxcnc.gif ']'
+ img=/usr/share/linuxcnc/linuxcnc.gif
+ '[' /usr/share/linuxcnc/linuxcnc.gif '!=' '' ']'
+ '[' -x /usr/lib/tcltk/linuxcnc/bin/popimage ']'
+ echo 'Starting LinuxCNC server program: linuxcncsvr'
+ /usr/lib/tcltk/linuxcnc/bin/popimage /usr/share/linuxcnc/linuxcnc.gif 5
+ program_available linuxcncsvr
+ type -path linuxcncsvr
+ export INI_FILE_NAME=/home/pi/linuxcnc/configs/Lathe/Lathe.ini
+ INI_FILE_NAME=/home/pi/linuxcnc/configs/Lathe/Lathe.ini
+ linuxcncsvr -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini
+ echo 'Loading Real Time OS, RTAPI, and HAL_LIB modules'
+ /etc/init.d/realtime start
+ export HAL_RTMOD_DIR=/usr/lib/linuxcnc/modules
+ HAL_RTMOD_DIR=/usr/lib/linuxcnc/modules
+ '[' io '!=' '' ']'
+ echo 'Starting LinuxCNC IO program: io'
+ program_available io
+ type -path io
+ halcmd loadusr -Wn iocontrol io -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini
+ '[' -n halui ']'
+ echo 'Starting HAL User Interface program: halui'
+ program_available halui
+ type -path halui
+ halcmd loadusr -Wn halui halui -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var TWOPASS -sec HAL -num 1
+ TWOPASS=
+ '[' -n '' ']'
+ NUM=1
++ inivar -tildeexpand -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var HALFILE -sec HAL -num 1
+ CFGFILE=Lathe.hal
+ '[' -n Lathe.hal ']'
+ IFS='\ '
+ read CFGFILE CFGFILE_ARGS
+ foundmsg=
+ saveIFS='
+ IFS=:
+ explicit_file_in_hallib=Lathe.hal
+ '[' -z Lathe.hal ']'
+ '[' Lathe.hal '!=' Lathe.hal ']'
+ '[' L = / ']'
+ for pathdir in $HALLIB_PATH
+ foundfile=./Lathe.hal
+ '[' -r ./Lathe.hal ']'
+ foundmsg='Found file(REL): ./Lathe.hal'
+ break
+ '[' -d ./Lathe.hal ']'
+ IFS='
+ '[' -z 'Found file(REL): ./Lathe.hal' ']'
+ echo 'Found file(REL): ./Lathe.hal'
+ CFGFILE=./Lathe.hal
+ case $CFGFILE in
+ halcmd -i /home/pi/linuxcnc/configs/Lathe/Lathe.ini -f ./Lathe.hal
Note: Using POSIX non-realtime
hm2/hm2_7c81.0: Low Level init 0.15
hm2/hm2_7c81.0: Smart Serial Firmware Version 43
hm2/hm2_7c81.0: 57 I/O Pins used:
hm2/hm2_7c81.0: IO Pin 000 (P1-01/DB25-01): IOPort
hm2/hm2_7c81.0: IO Pin 001 (P1-02/DB25-14): IOPort
hm2/hm2_7c81.0: IO Pin 002 (P1-03/DB25-02): StepGen #3, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 003 (P1-04/DB25-15): StepGen #3, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 004 (P1-05/DB25-03): StepGen #2, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 005 (P1-06/DB25-16): StepGen #2, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 006 (P1-07/DB25-04): StepGen #1, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 007 (P1-08/DB25-17): StepGen #1, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 008 (P1-09/DB25-05): StepGen #0, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 009 (P1-11/DB25-06): StepGen #0, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 010 (P1-13/DB25-07): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_7c81.0: IO Pin 011 (P1-15/DB25-08): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_7c81.0: IO Pin 012 (P1-17/DB25-09): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_7c81.0: IO Pin 013 (P1-19/DB25-10): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_7c81.0: IO Pin 014 (P1-21/DB25-11): IOPort
hm2/hm2_7c81.0: IO Pin 015 (P1-23/DB25-12): IOPort
hm2/hm2_7c81.0: IO Pin 016 (P1-25/DB25-13): IOPort
hm2/hm2_7c81.0: IO Pin 017 (J5-TX0): IOPort
hm2/hm2_7c81.0: IO Pin 018 (J6-TX1): IOPort
hm2/hm2_7c81.0: IO Pin 019 (P2-01/DB25-01): IOPort
hm2/hm2_7c81.0: IO Pin 020 (P2-02/DB25-14): IOPort
hm2/hm2_7c81.0: IO Pin 021 (P2-03/DB25-02): IOPort
hm2/hm2_7c81.0: IO Pin 022 (P2-04/DB25-15): IOPort
hm2/hm2_7c81.0: IO Pin 023 (P2-05/DB25-03): StepGen #6, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 024 (P2-06/DB25-16): StepGen #6, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 025 (P2-07/DB25-04): StepGen #5, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 026 (P2-08/DB25-17): StepGen #5, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 027 (P2-09/DB25-05): StepGen #4, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 028 (P2-11/DB25-06): StepGen #4, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 029 (P2-13/DB25-07): IOPort
hm2/hm2_7c81.0: IO Pin 030 (P2-15/DB25-08): IOPort
hm2/hm2_7c81.0: IO Pin 031 (P2-17/DB25-09): IOPort
hm2/hm2_7c81.0: IO Pin 032 (P2-19/DB25-10): IOPort
hm2/hm2_7c81.0: IO Pin 033 (P2-21/DB25-11): IOPort
hm2/hm2_7c81.0: IO Pin 034 (P2-23/DB25-12): IOPort
hm2/hm2_7c81.0: IO Pin 035 (P2-25/DB25-13): IOPort
hm2/hm2_7c81.0: IO Pin 036 (J5-TXEN0): IOPort
hm2/hm2_7c81.0: IO Pin 037 (J6-TXEN1): IOPort
hm2/hm2_7c81.0: IO Pin 038 (P7-01/DB25-01): IOPort
hm2/hm2_7c81.0: IO Pin 039 (P7-02/DB25-14): IOPort
hm2/hm2_7c81.0: IO Pin 040 (P7-03/DB25-02): IOPort
hm2/hm2_7c81.0: IO Pin 041 (P7-04/DB25-15): IOPort
hm2/hm2_7c81.0: IO Pin 042 (P7-05/DB25-03): IOPort
hm2/hm2_7c81.0: IO Pin 043 (P7-06/DB25-16): IOPort
hm2/hm2_7c81.0: IO Pin 044 (P7-07/DB25-04): IOPort
hm2/hm2_7c81.0: IO Pin 045 (P7-08/DB25-17): IOPort
hm2/hm2_7c81.0: IO Pin 046 (P7-09/DB25-05): IOPort
hm2/hm2_7c81.0: IO Pin 047 (P7-11/DB25-06): IOPort
hm2/hm2_7c81.0: IO Pin 048 (P7-13/DB25-07): IOPort
hm2/hm2_7c81.0: IO Pin 049 (P7-15/DB25-08): IOPort
hm2/hm2_7c81.0: IO Pin 050 (P7-17/DB25-09): IOPort
hm2/hm2_7c81.0: IO Pin 051 (P7-19/DB25-10): IOPort
hm2/hm2_7c81.0: IO Pin 052 (P7-21/DB25-11): IOPort
hm2/hm2_7c81.0: IO Pin 053 (P7-23/DB25-12): IOPort
hm2/hm2_7c81.0: IO Pin 054 (P7-25/DB25-13): IOPort
hm2/hm2_7c81.0: IO Pin 055 (P5-RX0): IOPort
hm2/hm2_7c81.0: IO Pin 056 (P6-RX1): IOPort
hm2/hm2_7c81.0: registered
+ NUM=2
++ inivar -tildeexpand -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var HALFILE -sec HAL -num 2
+ CFGFILE=custom.hal
+ '[' -n custom.hal ']'
+ IFS='\ '
+ foundmsg=
+ saveIFS='
+ IFS=:
+ explicit_file_in_hallib=custom.hal
+ '[' -z custom.hal ']'
+ '[' custom.hal '!=' custom.hal ']'
+ '[' c = / ']'
+ foundfile=./custom.hal
+ '[' -r ./custom.hal ']'
+ foundmsg='Found file(REL): ./custom.hal'
+ break
+ '[' -d ./custom.hal ']'
+ IFS='
+ '[' -z 'Found file(REL): ./custom.hal' ']'
+ echo 'Found file(REL): ./custom.hal'
+ CFGFILE=./custom.hal
+ case $CFGFILE in
+ halcmd -i /home/pi/linuxcnc/configs/Lathe/Lathe.ini -f ./custom.hal
+ NUM=3
++ inivar -tildeexpand -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var HALFILE -sec HAL -num 3
+ CFGFILE=
+ '[' -n '' ']'
+ echo 'Starting TASK program: milltask'
+ program_available milltask
+ type -path milltask
+ NUM=1
+ halcmd loadusr -Wn inihal milltask -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini
++ inivar -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var HALCMD -sec HAL -num 1
+ HALCOMMAND=
+ '[' -n '' ']'
+ halcmd start
+ run_applications
+ NUM=1
++ inivar -tildeexpand -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini -var APP -sec APPLICATIONS -num 1
+ APPFILE=
+ '[' -z '' ']'
+ return
+ echo 'Starting DISPLAY program: axis'
+ result=0
+ program_available axis
+ type -path axis
+ axis -ini /home/pi/linuxcnc/configs/Lathe/Lathe.ini
note: MAXV max: 1.000 units/sec 60.000 units/min
note: LJOG max: 1.000 units/sec 60.000 units/min
note: LJOG default: 0.250 units/sec 15.000 units/min
note: jog_order='ZX'
note: jog_invert=set(['X'])
Last edit: 06 Mar 2021 13:44 by 1RandomSquirrel. Reason: more info
06 Mar 2021 14:31 #201188
Yeah, you are not running a real time kernel, so watchdog timeouts are expected.
- Thank you received: 4654
07 Mar 2021 01:21 #201244
Replied by andypugh on topic Rpi 400, 7c85 to 7185s setup? xylotex
You should be able to get the realtime kernel with:
sudo apt-get install linux-image-4.19.71-rt24-v7l+
(from linuxcnc.org/docs/2.8/html/getting-start...lling_on_raspbian_10 )
The following user(s) said Thank You: 1RandomSquirrel
- 1RandomSquirrel
08 Mar 2021 01:42 #201384
by 1RandomSquirrel
Thanks I was able to get it working. Atleast the proof of concept. It was a combination of my .hal file being wrong and the db25 pins. I will try to post my hal and ini files after I make sure the bugs are out of them.
I did end up going back and changing these back to the original numbers.
Steplen =5000
StepSpace=5000
DirSetup=10000
DirHold=10000
Andy thanks for posting those docs it made me go back and look at things again.
Steplen =5000
StepSpace=5000
DirSetup=10000
DirHold=10000
- 1RandomSquirrel
11 Mar 2021 23:11 #201902
by 1RandomSquirrel
Still working on a figuring out a few things.
Flood coolant on. I could use one of the pins on7c81 board say in p2 or p7 but i would like to use a pin on the the 7i85 for simplicity i used flood coolant set as gpio pin 000 and i can see on with the voltmeter that db1 turns on and off. But i cannot find it on the 7i85s. is there a way i am supposed to use the pins say on tb1 like one of the differential outputs or just tb1 pin 3?
hm2/hm2_7c81.0: IO Pin 010 (P1-13/DB25-07): IOPort
hm2/hm2_7c81.0: IO Pin 011 (P1-15/DB25-08): IOPort
hm2/hm2_7c81.0: IO Pin 012 (P1-17/DB25-09): IOPort
hm2/hm2_7c81.0: IO Pin 013 (P1-19/DB25-10): IOPort
hm2/hm2_7c81.0: IO Pin 023 (P2-05/DB25-03): IOPort
hm2/hm2_7c81.0: IO Pin 024 (P2-06/DB25-16): IOPort
hm2/hm2_7c81.0: IO Pin 025 (P2-07/DB25-04): IOPort
hm2/hm2_7c81.0: IO Pin 026 (P2-08/DB25-17): IOPort
hm2/hm2_7c81.0: IO Pin 027 (P2-09/DB25-05): IOPort
hm2/hm2_7c81.0: IO Pin 028 (P2-11/DB25-06): IOPort
hm2/hm2_7c81.0: IO Pin 035999o (P2-25/DB25-13): IOPort
hm2/hm2_7c81.0: registered# Generated by PNCconf at Sun Mar 7 17:18:55 2021
# Using LinuxCNC version: Master (2.9)
# overwritten when you run PNCconf again
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_rpspi config=" num_encoders=0 num_pwmgens=0 num_stepgens=4"
setp [HMOT](CARD0).watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.z,pid.s
addf [HMOT](CARD0).read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf [HMOT](CARD0).write servo-thread
# external output signals
# --- COOLANT-FLOOD ---
setp [HMOT](CARD0).gpio.000.is_output true
# setp [HMOT](CARD0).gpio.000.invert_output true
net coolant-flood => [HMOT](CARD0).gpio.000.out
# external input signals
# AXIS X JOINT 0
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp pid.x.maxerror 0.000500
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-pos-fb => pid.x.feedback
net x-output <= pid.x.output
# Step Gen signals/setup
setp [HMOT](CARD0).stepgen.00.dirsetup [JOINT_0]DIRSETUP
setp [HMOT](CARD0).stepgen.00.dirhold [JOINT_0]DIRHOLD
setp [HMOT](CARD0).stepgen.00.steplen [JOINT_0]STEPLEN
setp [HMOT](CARD0).stepgen.00.stepspace [JOINT_0]STEPSPACE
setp [HMOT](CARD0).stepgen.00.position-scale [JOINT_0]STEP_SCALE
setp [HMOT](CARD0).stepgen.00.step_type 0
setp [HMOT](CARD0).stepgen.00.control-type 1
setp [HMOT](CARD0).stepgen.00.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.00.maxvel [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= joint.0.motor-pos-cmd
net x-vel-cmd <= joint.0.vel-cmd
net x-output <= [HMOT](CARD0).stepgen.00.velocity-cmd
net x-pos-fb <= [HMOT](CARD0).stepgen.00.position-fb
net x-pos-fb => joint.0.motor-pos-fb
net x-enable <= joint.0.amp-enable-out
net x-enable => [HMOT](CARD0).stepgen.00.enable
# ---setup home / limit switch signals---
net x-home-sw => joint.0.home-sw-in
net x-neg-limit => joint.0.neg-lim-sw-in
net x-pos-limit => joint.0.pos-lim-sw-in
# AXIS Z JOINT 1
setp pid.z.Pgain [JOINT_1]P
setp pid.z.Igain [JOINT_1]I
setp pid.z.Dgain [JOINT_1]D
setp pid.z.bias [JOINT_1]BIAS
setp pid.z.FF0 [JOINT_1]FF0
setp pid.z.FF1 [JOINT_1]FF1
setp pid.z.FF2 [JOINT_1]FF2
setp pid.z.deadband [JOINT_1]DEADBAND
setp pid.z.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror 0.000500
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-pos-fb => pid.z.feedback
net z-output <= pid.z.output
setp [HMOT](CARD0).stepgen.01.dirsetup [JOINT_1]DIRSETUP
setp [HMOT](CARD0).stepgen.01.dirhold [JOINT_1]DIRHOLD
setp [HMOT](CARD0).stepgen.01.steplen [JOINT_1]STEPLEN
setp [HMOT](CARD0).stepgen.01.stepspace [JOINT_1]STEPSPACE
setp [HMOT](CARD0).stepgen.01.position-scale [JOINT_1]STEP_SCALE
setp [HMOT](CARD0).stepgen.01.step_type 0
setp [HMOT](CARD0).stepgen.01.control-type 1
setp [HMOT](CARD0).stepgen.01.maxaccel [JOINT_1]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.01.maxvel [JOINT_1]STEPGEN_MAXVEL
net z-pos-cmd <= joint.1.motor-pos-cmd
net z-vel-cmd <= joint.1.vel-cmd
net z-output <= [HMOT](CARD0).stepgen.01.velocity-cmd
net z-pos-fb <= [HMOT](CARD0).stepgen.01.position-fb
net z-pos-fb => joint.1.motor-pos-fb
net z-enable <= joint.1.amp-enable-out
net z-enable => [HMOT](CARD0).stepgen.01.enable
net z-home-sw => joint.1.home-sw-in
net z-neg-limit => joint.1.neg-lim-sw-in
net z-pos-limit => joint.1.pos-lim-sw-in
# SPINDLE
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
setp pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp pid.s.error-previous-target true
setp pid.s.maxerror 0.000500
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
setp [HMOT](CARD0).stepgen.02.dirsetup [SPINDLE_0]DIRSETUP
setp [HMOT](CARD0).stepgen.02.dirhold [SPINDLE_0]DIRHOLD
setp [HMOT](CARD0).stepgen.02.steplen [SPINDLE_0]STEPLEN
setp [HMOT](CARD0).stepgen.02.stepspace [SPINDLE_0]STEPSPACE
setp [HMOT](CARD0).stepgen.02.position-scale [SPINDLE_0]STEP_SCALE
setp [HMOT](CARD0).stepgen.02.step_type 0
setp [HMOT](CARD0).stepgen.02.control-type 1
setp [HMOT](CARD0).stepgen.02.maxaccel [SPINDLE_0]MAX_ACCELERATION
setp [HMOT](CARD0).stepgen.02.maxvel [SPINDLE_0]MAX_VELOCITY
net spindle-enable => [HMOT](CARD0).stepgen.02.enable
net spindle-vel-cmd-rps => [HMOT](CARD0).stepgen.02.velocity-cmd
net spindle-vel-fb-rps <= [HMOT](CARD0).stepgen.02.velocity-fb
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm <= spindle.0.speed-out
net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-enable <= spindle.0.on
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
net spindle-revs => spindle.0.revs
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net axis-select-x halui.axis.x.select
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-z halui.axis.z.select
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.1.is-homed
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
net spindle-manual-stop halui.spindle.0.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
11 Mar 2021 23:36 - 11 Mar 2021 23:37 #201907
You can get the 7I85S terminal to DB25 pin mapping from the 7I85S manual (page 4)
Note that there will not be any free 5V outputs unless you reduce the number of stepgens (say to 3)
(The 7I85S's serial port TX line could be used but it does not have full 5V swing
since is a RS-485 type driver)
Last edit: 11 Mar 2021 23:37 by PCW.
Time to create page: 0.189 seconds
