[Resolved] adding control of the spindle with 7i96 tools
05 Mar 2021 14:31 - 19 Mar 2021 15:31 #201099 by Ewok2
Hello
I have a CnC working but with a potentiometer to control the spindle speed.
The Spindle is connected to a Power supply whitcgh accept a 0-10V control.
I would like to control the spindle speed with the 7i96 mesa card.
I have the 7i96 tool installed (latest version).
I have connected the Spindle On cable to Ouput 0
I have connected the Spindle 0-10V cable to Ouput 1
I have configured this Output with Spindle On and Sindle CW in the 7i96 Tools
I have read my "old" ini file but the Spindle documentation is not so helpfull :-)
In the Spindle type it is not obvious wich one I have to select...
Did someone have a link on a page where there are some advice or explanation how to configure it?
Many thanks
Last edit: 19 Mar 2021 15:31 by Ewok2.
05 Mar 2021 16:48 - 05 Mar 2021 17:22 #201106 by PCW
The OUT pins on a 7I96 are digital (Either on or off) so cannot give
an adjustable 0 to 10V signal directly but can by using PWM
and a filter, something like this:
Where R1 is perhaps 1K
R2 is 10K
C1 is 100 uF
You would also have to setup PWM in your hal file using the pwmgen component
Last edit: 05 Mar 2021 17:22 by PCW.
05 Mar 2021 20:16 #201123 by Ewok2
Thanks for Reply
I am not sure to understand the wiring around the 7i96 Out +/- and the 10V.
I need an external 10V supply ?
05 Mar 2021 20:55 - 05 Mar 2021 20:55 #201128 by PCW
If your drive supplies 10V then that can be used.
Depending on how much current the drives 10V can supply
you may need to adjust the resistor/capacitor values
Last edit: 05 Mar 2021 20:55 by PCW.
05 Mar 2021 22:42 #201142 by RotarySMP
Replied by RotarySMP on topic adding control of the spindle with 7i96 tools
I used one of these with my 7i96. Worked fine.
www.ebay.com/itm/PWM-To-Voltage-Converte...7:g:YFEAAOSw7Cdfybce
06 Mar 2021 10:13 #201166 by Ewok2
Thanks for the electronics part. I will by this module.
But what about the configuration part?
I was wondering, the On/Off of the spindle was a Wire.
Should I put the Output to High to simulate the short circuit ? or is it more complicate?
06 Mar 2021 12:01 #201176 by RotarySMP
I put up my HAL and wiring diagram in the first post of my mini -lathe thread.
forum.linuxcnc.org/26-turning/38280-pimp...e-mini-lathe?start=0
Mark
07 Mar 2021 11:59 #201281 by Ewok2
Thanks for the files.
Did you use the 7i96 Configuration Tool from JohnT to produce the ini and hal files ?
Did you connect the ON/OFF off the Spindle to an Outpus directly?
07 Mar 2021 14:44 #201295 by RotarySMP
Did you look at the schematics I posted? I am running a VFD, so the VFD enable, start and direction are all controlled directly by the 7i96, and the analog speed input is a PWM output from the 7i96, changed to a 0-10V analog signal by that little widget, and then input to the VFD.
Mark
19 Mar 2021 09:53 #202817 by Ewok2
Hello RotarySMP
I have received my small board to convert PWM to 0-10V.
It look likes yours.
It has also a 5V / 24V PMW selector.
Did the Mesa card Output send 5V or 24V ?
Moderators: PCWjmelson
Time to create page: 0.314 seconds
