[Resolved] adding control of the spindle with 7i96 tools
5 years 7 months ago - 5 years 7 months ago #201099 by Ewok2
Hello
I have a CnC working but with a potentiometer to control the spindle speed.
The Spindle is connected to a Power supply whitcgh accept a 0-10V control.
I would like to control the spindle speed with the 7i96 mesa card.
I have the 7i96 tool installed (latest version).
I have connected the Spindle On cable to Ouput 0
I have connected the Spindle 0-10V cable to Ouput 1
I have configured this Output with Spindle On and Sindle CW in the 7i96 Tools
I have read my "old" ini file but the Spindle documentation is not so helpfull :-)
In the Spindle type it is not obvious wich one I have to select...
Did someone have a link on a page where there are some advice or explanation how to configure it?
Many thanks
Last edit: 5 years 7 months ago by Ewok2.
5 years 7 months ago - 5 years 7 months ago #201106 by PCW
The OUT pins on a 7I96 are digital (Either on or off) so cannot give
an adjustable 0 to 10V signal directly but can by using PWM
and a filter, something like this:
Where R1 is perhaps 1K
R2 is 10K
C1 is 100 uF
You would also have to setup PWM in your hal file using the pwmgen component
Last edit: 5 years 7 months ago by PCW.
5 years 7 months ago #201123 by Ewok2
Thanks for Reply
I am not sure to understand the wiring around the 7i96 Out +/- and the 10V.
I need an external 10V supply ?
5 years 7 months ago - 5 years 7 months ago #201128 by PCW
If your drive supplies 10V then that can be used.
Depending on how much current the drives 10V can supply
you may need to adjust the resistor/capacitor values
5 years 7 months ago #201142 by RotarySMP
No eBay APP ID and/or Cert ID defined in Kunena configurationI used one of these with my 7i96. Worked fine.
5 years 7 months ago #201166 by Ewok2
Thanks for the electronics part. I will by this module.
But what about the configuration part?
I was wondering, the On/Off of the spindle was a Wire.
Should I put the Output to High to simulate the short circuit ? or is it more complicate?
Moderators: PCW, jmelson
Time to create page: 0.151 seconds
