6I25 --recover
5 years 7 months ago #201512 by silden
Hi All,
I have a 6I25 and wanted to run it in PCIE mode.
In order to do this I need to load a 6I25 bit file.
For this I generated one based on the VIVADO project in the HM2 source folder.
I used one of the existing files for 7I76 with a 7I85.
As a next step I changed the W7 jumper to up to get the 66MHz enabled.
Next I tried to read the current bit file and Mesaflash showed no HM2 FW exist.
I thought that should be fine due to the jumper change.
but Mesaflash throws an error when I try to load the bitfile.
the error is boot sector invalid.
Next I changed the jumper back to 33MHZ, but Mesaflash still shows no HM2FW and same error.
I hope someone can give me a hint how I can get this working and what I am doing wrong.
Please see the attached Bit file and VIVADO project.
BTW I tested the card yesterday in my WS and it was OK.
5 years 7 months ago #201516 by PCW
Replied by PCW on topic 6I25 in PCIE 66MHz mode
I don't think there really is much advantage to 66 MHz PCI clock on the 6I25
You can recover by using mesaflash's --recover mode
5 years 7 months ago - 5 years 7 months ago #201517 by silden
Replied by silden on topic 6I25 in PCIE 66MHz mode
Hi PCW,
I will try the recovery mode.
Still I would like to know what needs to be done to get the 66MHz working, even when it would be just for giggles.
It would probably help with NVME speeds and interrupts.
Can you please check the config I attached above?
This would be more than helpful.
Edit:
I tried - - recover with writing the fallback.bit but the card doesn’t come back. I set the jumper to 33MHz.
I wonder what I am doing wrong. Should I send the card to you -Mesa- for check out?
Last edit: 5 years 7 months ago by silden. Reason: tested suggestion
5 years 7 months ago - 5 years 7 months ago #202446 by silden
Replied by silden on topic 6I25 --recover
Hi All,
I changed the Jumper to test the 66MHz mode. The bit file I made based on the 6i26 Xilinx file was rejected from the loader and not written to the card.
However the card shows that NO HM2 Firmware is installed.
I tried the recover function with the eeprom disabled jumper in 33 and 66MHz with on veil.
It showed that the bitfile was witten to the card but after reboot an eemprom enable jumper change it still showed the message that the card has no HM2 FW. I removed the card from the slot to do this.
I tried to load the same 5I25 fall back bitfile as before and it shows that the boot loader is corrupted.
Is the card recoverable?
Why has this happened the only change I did was moving the jumper to 66MHz and no bitfile write?
Thank you
BTW the card is pulling down the Ethernet port when it is plugged in.
5 years 7 months ago #202473 by PCW
Replied by PCW on topic 6I25 --recover
If you corrupted the bootloader you must re-write the card in recover mode with the mesaflash option to re-write the bootloader
5 years 7 months ago - 5 years 7 months ago #203009 by silden
Hi PCW,
I tried several different combinations of --recover and the card looks like to be loading the file. But still has the same issue.
I tired:
- sudo mesaflash --device 6I25 --recover --write Fallback.bit -starts at address 1000 runs through
- sudo mesaflash --device 6I25 --recover --fix-boot-block --write Fallback.bit -starts at address 1000 runs through
- sudo mesaflash --device 5I25 --fix-boot-block --write Fallback.bit - start at address 0 stuck on erase
I think I may have not used the right combination
Can you please clarify which command I should issue to get rewrite the bootloader?
I tied with eemprom jumpered off and on.
Moderators: PCW, jmelson
Time to create page: 0.456 seconds
