7i96 Parameters
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
15 Mar 2021 12:06 #202337 by BigJohnT
7i96 Parameters was created by BigJohnT
I see 50 gpio parameters for the 7i96 and wonder what they do?
hm2_7i96.0.gpio.000.invert_output
hm2_7i96.0.gpio.000.is_opendrain
hm2_7i96.0.gpio.000.is_output
After hm2_7i96.0.gpio.010.is_output the invert_output setting is no longer there so I assume 0 - 10 are for the inputs?
hm2_7i96.0.gpio.011.invert_output
hm2_7i96.0.gpio.011.is_opendrain
JT
15 Mar 2021 12:28 #202339 by RotarySMP
Replied by RotarySMP on topic 7i96 Parameters
Are these not the individual pins of the expansion port?
Mark
15 Mar 2021 14:38 #202353 by PCW
Replied by PCW on topic 7i96 Parameters
GPIO 0 through 10 are routed to the isolated inputs on the 7I96
Because they are plain GPIO, the have the ability ro be changed to
output mode(even though this makes no sense on a 7I96)
Mesaflash's readhmid pinout list shows this:
Configuration pin-out:
IO Connections for TB3
Pin#                  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
TB3-1                   0   IOPort       None
TB3-2                   1   IOPort       None
TB3-3                   2   IOPort       None
TB3-4                   3   IOPort       None
TB3-5                   4   IOPort       None
TB3-6                   5   IOPort       None
TB3-7                   6   IOPort       None
TB3-8                   7   IOPort       None
TB3-9                   8   IOPort       None
TB3-10                  9   IOPort       None
TB3-11                 10   IOPort       None
TB3-13,14              11   IOPort       SSR              0        Out-00          (Out)
TB3-15,16              12   IOPort       SSR              0        Out-01          (Out)
TB3-17,18              13   IOPort       SSR              0        Out-02          (Out)
TB3-19,20              14   IOPort       SSR              0        Out-03          (Out)
TB3-21,22              15   IOPort       SSR              0        Out-04          (Out)
TB3-23,24              16   IOPort       SSR              0        Out-05          (Out)
IO Connections for TB1/TB2
TB1-2,3                17   IOPort       StepGen          0        Step/Table1     (Out)
TB1-4,5                18   IOPort       StepGen          0        Dir/Table2      (Out)
TB1-8,9                19   IOPort       StepGen          1        Step/Table1     (Out)
TB1-10,11              20   IOPort       StepGen          1        Dir/Table2      (Out)
TB1-14,15              21   IOPort       StepGen          2        Step/Table1     (Out)
TB1-16,17              22   IOPort       StepGen          2        Dir/Table2      (Out)
TB1-20,21              23   IOPort       StepGen          3        Step/Table1     (Out)
TB1-22,23              24   IOPort       StepGen          3        Dir/Table2      (Out)
TB2-2,3                25   IOPort       PWM              0        PWM             (Out)
TB2-4,5                26   IOPort       PWM              0        Dir             (Out)
TB2-7,8                27   IOPort       QCount           0        Quad-A          (In)
TB2-10,11              28   IOPort       QCount           0        Quad-B          (In)
TB2-13,14              29   IOPort       QCount           0        Quad-IDX        (In)
TB2-16,17              30   IOPort       SSerial          0        RXData0         (In)
TB2-18,19              31   IOPort       SSerial          0        TXData0         (Out)
Internal               32   IOPort       SSerial          0        TXEn0           (Out)
Internal               33   IOPort       SSR              0        AC Ref          (Out)
IO Connections for P1
P1-01/DB25-01          34   IOPort       None
P1-02/DB25-14          35   IOPort       None
P1-03/DB25-02          36   IOPort       None
P1-04/DB25-15          37   IOPort       None
P1-05/DB25-03          38   IOPort       None
P1-06/DB25-16          39   IOPort       None
P1-07/DB25-04          40   IOPort       None
P1-08/DB25-17          41   IOPort       None
P1-09/DB25-05          42   IOPort       None
P1-11/DB25-06          43   IOPort       None
P1-13/DB25-07          44   IOPort       None
P1-15/DB25-08          45   IOPort       None
P1-17/DB25-09          46   IOPort       None
P1-19/DB25-10          47   IOPort       None
P1-21/DB25-11          48   IOPort       None
P1-23/DB25-12          49   IOPort       None
P1-25/DB25-13          50   IOPort       None
The following user(s) said Thank You: BigJohnT
Moderators: PCWjmelson
