Max cable length between Mesa 5i25 and &7i77
- vmihalca
- Thank you received: 22
16 Mar 2021 06:43 #202453
by vmihalca
Max cable length between Mesa 5i25 and &7i77 was created by vmihalca
Hello,
I am trying to decide if I will keep the pc in the machine cabinet and buy 5 meters long vga and usb cables to the monitor, or buy a longer db 25 cable. Is there a max length for the db 25 cable? Can I bump into delay and noise issues with a 5 or 6 meters long paralel port cable?
Thanks,
Vasi
Thanks,
Vasi
- bevins
- Thank you received: 338
16 Mar 2021 11:28 #202464
by bevins
Definitely extend your usb and monitor cables or you will most likely have issues with the mesa cable. I think I remember pcw saying max 10 foot cable.
Replied by bevins on topic Max cable length between Mesa 5i25 and &7i77
Hello,
Thanks,
Vasi
- Michael
- Thank you received: 59
16 Mar 2021 13:11 - 16 Mar 2021 13:14 #202470
by Michael
Replied by Michael on topic Max cable length between Mesa 5i25 and &7i77
I recall 10 to 15 feet max. If you want to keep the computer outside the cabinet at the control you can run a 7i92 inside the cabinet instead of a 5i25 and get away with running a significantly smaller and longer ethernet cable from the computer to the cabinet. The ethernet delays are not as significant of an issue.
This also allows a smaller form factor computer case. Access to USB ports at the control. Alot less long wire runs.
Last edit: 16 Mar 2021 13:14 by Michael.
Time to create page: 0.120 seconds
