7i73 inputs question (pull-down resistors) (SOLVED)
- spumco
- Thank you received: 874
17 Mar 2021 21:24 - 17 Mar 2021 21:46 #202647
by spumco
7i73 inputs question (pull-down resistors) (SOLVED) was created by spumco
Wiring up my first Linux/Mesa machine now and am in need of some guidance on 7i73 inputs.
Manual states P1/0 to P1/7 P2/0-P2/7 require pull-up or pull-down resistors when used for switch sensing.
So... if one side of a momentary switch is connected to the 3.3v supply on 7i73 (P/29), and the other is connected toP1/7 P2/7, then I would also connect a 4.7k resistor between P1/7 P2/7 and GND - making it a pull-down resistor?
If I have four switches onP1/4 P2/4 through P1/7 P2/7, each one would need a 4.7k resistor connected to GND (along with the switch conductor)?
If I've got it right, any confirmation would be helpful. And if I'm wrong, an explanation in really small words and a diagram would be favorite.
Thanks,
Ralph
Edited to correct port designation error
Manual states
Thanks,
Ralph
Last edit: 17 Mar 2021 21:46 by spumco.
- Thank you received: 5247
17 Mar 2021 21:30 #202649
Replied by PCW on topic 7i73 inputs question (pull-down resistors)
That's correct.
The pins have no internal pull-up or pull-down resistors
so have an undefined state if left unconnected (when the switch is off)
The pull-up or pull-down resistors define the pin state when unconnected
- spumco
17 Mar 2021 21:45 #202651
by spumco
Replied by spumco on topic 7i73 inputs question (pull-down resistors)
Thanks much, looking forward to getting this thing moving around.
Time to create page: 0.193 seconds
