- Hardware & Machines
- Driver Boards
- Debian 10 Linuxcnc 2.8.0 - Pico Systems univstepdiags program not found error -
- dansawyer
21 Mar 2021 23:43 #203175
by dansawyer
Debian 10 Linuxcnc 2.8.0 - Pico Systems univstepdiags program not found error - was created by dansawyer
Pico Systems univstepdiags has been downloaded and unziped.
The permissions are correct: -rwxr-xr-x 1 dan dan 68958 May 6 2008 univstepdiags
The file appears to by uncorrupted:
md5sum univstepdiags
1eacf63957f1a236ad85d1c85c2d4db4 univstepdiags
However it fails to execute: sudo ./univstepdiags
sudo: unable to execute ./univstepdiags: No such file or directory
I downloaded it an another system and it started without error. This appears to be related to Debian 10
- jmelson
- Thank you received: 126
22 Mar 2021 00:13 #203180
by jmelson
Replied by jmelson on topic Debian 10 Linuxcnc 2.8.0 - Pico Systems univstepdiags program not found error -
Ah, you are probably trying to run this on a 64-bit system, the files are not compatible (without loading a compatibility library).
Try pico-systems.com/codes/univstepdiags_64.tgz
Note that a few things do not format printing properly on this, expecially the combining and breaking apart the indivdual bytes of the 24-bit encoder position.
I really OUGHT to fix this - I fixed the real LinuxCNC driver.
Side note -- the Linux error message is STUPID, it should report that the file is not compatible with the runtime environment, or something like that.
Jon
Jon
- dansawyer
22 Mar 2021 02:25 #203193
by dansawyer
Replied by dansawyer on topic Debian 10 Linuxcnc 2.8.0 - Pico Systems univstepdiags program not found error -
Thank you for the reply. It is now running.
- Driver Boards
Time to create page: 0.156 seconds
