Pico Universal Stepper Voltage questions
23 Mar 2021 03:29 #203342 by dansawyer
Replied by dansawyer on topic Pico Universal Stepper Voltage questions
This is the onliy entry that relates at all to a parallel port.
01:00.0 Communication controller: MosChip Semiconductor Technology Ltd. PCI 9835 Multi-I/O Controller (rev 01)
Subsystem: LSI Logic / Symbios Logic PCI 9835 Multi-I/O Controller
Flags: medium devsel, IRQ 21
I/O ports at d050
I/O ports at d040
I/O ports at d030
I/O ports at d020
I/O ports at d010
I/O ports at d000
Kernel modules: parport_serial
23 Mar 2021 03:57 #203346 by dansawyer
Yes. I think you are correct. Below is the dmesg output showing 2 parallel ports.
I will check for the pin headers and look for an adapter. I assume it will be more straight forward going forward to use the built in port than the pci one.
Thanks for your help. Dan
dmesg |grep par
[ 0.112811] Booting paravirtualized kernel on bare hardware
[ 6.070766] Asymmetric key parser 'x509' registered
[ 9.770392] ppdev: user-space parallel port driver
[ 9.800816] parport0: PC-style at 0x378 (0x778)
[ 9.936114] parport0: irq 5 detected
[ 10.105613] parport1: PC-style at 0xd030, irq 21 [PCSPP,TRISTATE,EPP]
[ 10.207493] parport_serial 0000:01:00.0: 0000:01:00.0: unknown NetMos/Mostech device
It also reports USC via:
./univstepdiags 0xd030 bus
io addr = d030
parport addr 0xd030
Bus Map
Board Addr Type Ver.
0 Unknown f
1 Encoder f
2 DAC-16 f
3 DIO f
4 Univ. Stepper f
6 Unknown 6f
7 Unknown 7f
8 Unknown 8f
9 Unknown 9f
a Unknown af
b Unknown bf
c Unknown cf
d Unknown df
e Unknown ef
f No Board ff
23 Mar 2021 13:32 - 23 Mar 2021 13:32 #203390 by jmelson
Replied by jmelson on topic Pico Universal Stepper Voltage questions
I/O ports at d050
I/O ports at d040
I/O ports at d030
I/O ports at d020
I/O ports at d010
I/O ports at d000
OK, so ONE of those addresses is the EPP parallel port, but I can't tell you which one it is.
You will have to try all of them.
Jon
Last edit: 23 Mar 2021 13:32 by jmelson.
23 Mar 2021 13:35 #203391 by jmelson
Yes, if it exists (seems so from the lspci and /proc/ioports output) that could be easier.
dmesg |grep par
io addr = d030
parport addr 0xd030
Bus Map
0 Unknown f
1 Encoder f
2 DAC-16 f
3 DIO f
4 Univ. Stepper f
6 Unknown 6f
7 Unknown 7f
8 Unknown 8f
9 Unknown 9f
a Unknown af
b Unknown bf
c Unknown cf
d Unknown df
e Unknown ef
f No Board ff
Yes, the above output is still showing no communication. You SHOULD get a list of ONW board only at address 0, and then 15 "No Board". The above list shows a bunch of "Unknown" and other boards which are not present. That is wrong.
Jon
Moderators: PCWjmelson
Time to create page: 0.161 seconds
