Hardware & Machines
Driver Boards
7i92 Configuration Tool
BigJohnT
Offline
Administrator
Thank you received: 994
30 Mar 2021 13:15 #204119
by BigJohnT
I'm starting over with my 7i92 configuration tool using all the knowledge I gained in the past 6 months or so about what tools to not use to make a deb and some good things I learned about Python. Currently the only thing it will do is to read, flash and reload the card. The tool comes with the latest firmwares. Like the other tools it's a deb you can install and it puts a menu item in the CNC menu.
The tool is located here.
github.com/jethornton/7i92
If anyone cares to try that out let me know if you see any issues.
JT
Hardware & Machines
Driver Boards
Time to create page: 0.093 seconds
