What to put control board in?
5 years 6 months ago #205350 by MattK
Hi All,
I've purchased the components to build up a control system based upon a mesa 7i96 for a 3 axis cnc, what should I put it all in?
Stuff to house
4 stepper motor drivers
2 48v Power Supplies
1 5v/12v power supply
Mesa card
future spindle control
maybe I am being dumb but my search terms "electronics cabinent", "electronic equipment enclosure box" are either bringing back a small exterior weatherproof wiring box or a serveral hundred dollar which would work quite nicely other than the cost.
What are folks using to house all their electronics? is there something sub $100 which fits the bill that is designed or intended for other purposes?
Thanks for your advice
5 years 6 months ago #205351 by tommylight
Due to lack of anything "useful" or "appropriate", i use the plastic fuse boxes as can be seen in the link bellow, at least they look half decent! :)
forum.linuxcnc.org/show-your-stuff/38547...plasma-build?start=0
5 years 6 months ago #205354 by Benb
Replied by Benb on topic What to put control board in?
Have look at this link, although they are just junction boxes nema 3/4 ie not dust proof or water tight. The hammond JB's are in your price range, to see them drill down the web page.
www.automationdirect.com/adc/shopping/ca...%20-%2020%22&start=0
  • BeagleBrainz
  • New Member
  • New Member
5 years 6 months ago - 5 years 6 months ago #205376 by BeagleBrainz
Replied by BeagleBrainz on topic What to put control board in?
I picked up a enclosed 18 unit rack cabinet second hand. Deep enough to have panels mounted in the centre and have components mounted either side.
Recent update is here forum.linuxcnc.org/show-your-stuff/40259...uild?start=10#205392
Last edit: 5 years 6 months ago by BeagleBrainz.
5 years 6 months ago #205389 by Michael
You didn't mention what you are doing for a pc. But I hollowed out an ATX Tower case and placed my computer with psu in it. The 48v psu fit where the drive bays go, stepper drives below that. Mesa card below pc mother board. Made some custom relay pcbs to fit the rest of what I needed. All the wiring came in and out via cheap plastic cable glands near or on plates over the pci slot areas.
Cost, damn near free
The following user(s) said Thank You: tommylight, BeagleBrainz
5 years 6 months ago #205430 by MattK
Replied by MattK on topic What to put control board in?
For a PC, I've been using a dell optiplex 755 as it has a parallel port and I took what I had been using for a 2nd monitor for my work laptop (no fun just looking at a laptop screen so I want that back). End game I wont need the parallel port with the new mesa card setup.
Recently my parents upgraded their dell 2350 all in one as the hard disk was on the way out. They gave it and I am in the process of replacing the hard drive and setting up with linuxcnc. Although the all in one has a fan and I assume that I will have dust problems with it, it does have a 23" touch screen and looks quite nice.
I've been searching and like the fuse panels with the clear plastic door so I will probably buy one of those
Moderators: PCW, jmelson
Time to create page: 0.331 seconds
