7i76ED + 7i85S and Encoder on FPGA card not reading signals
5 years 6 months ago - 5 years 6 months ago #205650 by Aciera
I have just upgraded a machine with glass scales and added a 7i85S to a 7i76ED. I have successfully set up the scales using encoder.00, .01, and .02 leaving encoder.03 on the 7i85S unused.
The spindle feedback going to the encoder connection of the 7i76ED was left as before and I expected that to be accessible as encoder.04 now with the new setup. The pins show in HAL-show but I cannot seem to get any signals.
I had to use the unused encoder.03 connector on the 7i85S to get the signals into hal for now but I get nothing on encoder.04 when connected to the 7i76ED.
So my setup: 7i76ED and a 7i85S connected to the expansion connector P1 and a 7i73 on the SSerial Port.
I flashed the card using the file: 7i76e_7i76x1_7i85sx2d.bit
In hal I load the module with:
loadrt hm2_eth board_ip="192.168.1.121" config=" num_encoders=5 num_pwmgens=0 num_stepgens=5 sserial_port_0=11xxxx"
Any ideas?
Last edit: 5 years 6 months ago by Aciera.
5 years 6 months ago - 5 years 6 months ago #205651 by PCW
Not sure but you may need to set num_encoders=6
Edit no, for 7i76e_7i76x1_7i85sx2d.bit the 7I76E encoder is number 8
If you only have one 7I85S connected you should probably use
7i76e_7i76x1_7i85sx1D.bit (The 7I76E encoder will be number 4 on this firmware)
Last edit: 5 years 6 months ago by PCW.
5 years 6 months ago #207352 by linuxcnc4less
I will definitely appreciate you sharing your results and working configuration.
Moderators: PCW, jmelson
Time to create page: 0.052 seconds
