7i80db connect to 7i76x2 and 7i74
- nhanpham
19 Apr 2021 07:53 #206365
by nhanpham
7i80db connect to 7i76x2 and 7i74 was created by nhanpham
Dear all,
I'm currently working on implementing LinuxCNC on the following setup: one MESA 7i80db-16 FPGA board, that is connected to 2 MESA 7i76 boards and a MESA 7i74 for 4 SSI encoders. Do you know which .bit file should I flash on the FPGA for this specific configuration?
- Thank you received: 7440
19 Apr 2021 08:56 #206367
Replied by tommylight on topic 7i80db connect to 7i76x2 and 7i74
Might have to wait for PCW or make the firmware yourself ( it is open source ).
I had a similar setup for 5i25/7i77/7i74 with 6 SSI encoders, been running daily for over 4 years.
- nhanpham
19 Apr 2021 09:09 #206370
by nhanpham
Hi, I am newbie. How do I make the firmware?
I'm downloading the Xilinx_ISE_14.7. It's very large
thanks
Replied by nhanpham on topic 7i80db connect to 7i76x2 and 7i74
thanks
- nhanpham
19 Apr 2021 09:10 #206371
by nhanpham
can you share your config file. I'm beginning for Linux cnc
thanks you very much
19 Apr 2021 14:03 #206386
The following user(s) said Thank You: nhanpham
- Thank you received: 5288
19 Apr 2021 15:17 #206397
Replied by PCW on topic 7i80db connect to 7i76x2 and 7i74
- nhanpham
19 Apr 2021 15:21 #206398
by nhanpham
Ok thank you very much..
Can i use port 4 for INPUT/OUTPUT IO control?
19 Apr 2021 15:24 #206400
Yes, its just GPIO
I included the new pinout file so you can take a look at the layout
(or modify it)
(or modify it)
- nhanpham
19 Apr 2021 15:26 #206401
by nhanpham
Ok, I will try to modify it.. Thank you for your helping
Yes, its just GPIO
(or modify it)
