7i95 Configuration Tool
- BigJohnT
- Thank you received: 994
29 Apr 2021 00:01 #207341
by BigJohnT
7i95 Configuration Tool was created by BigJohnT
I just pushed the start of the 7i95 Configuration Tool. It should make a basic configuration. If anyone has a 7i95 ( I'm out of stock ) can you check the configuration with your card?
JT
JT
- BigJohnT
29 Apr 2021 13:30 #207369
by BigJohnT
Replied by BigJohnT on topic 7i95 Configuration Tool
I just pushed more content to the 7i95 Configuration tool and it should now make a working configuration. Only a few things to finish adding tomorrow...
JT
JT
- aventtini
- Visitor
30 Apr 2021 07:16 #207430
by aventtini
Replied by aventtini on topic 7i95 Configuration Tool
That good. I just started a 5 axis machine with 7i95 . În currios if it works with SSI encoder direct. Next week I Will try to finish the panel , siemens dc motors 4kw , SSI encoders, or incremental 8000ppr . Drivers are step dir dc , 7i95 . Travel îs 3x2m . I Will make a post about it next week
- BigJohnT
30 Apr 2021 22:11 #207496
by BigJohnT
I keep adding to the 7i95 Configuration Tool so feedback is crucial for me to make sure everything is working as expected with the Configuration Tool.
You might want to start a new thread asking about the SSI encoders... I don't even know what one is.
JT
JT
Time to create page: 0.217 seconds
