Mesa watchdog.timeout_ns
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
04 May 2021 12:03 - 04 May 2021 12:05 #207823 by BigJohnT
Mesa watchdog.timeout_ns was created by BigJohnT
How does the watchdog.timeout_ns relate to the servo period?
Should it be the same as the servo period?
JT
Last edit: 04 May 2021 12:05 by BigJohnT.
04 May 2021 13:38 #207827 by PCW
Replied by PCW on topic Mesa watchdog.timeout_ns
The timeout needs to be longer than the servo period
If it were set to the same period, 1 usec of jitter could
cause a watchdog bite.
If you consider that the watchdog is mainly for safety,
I think a reasonable number is 10 to 50 ms. That is the time
outputs and stepgens and analog outs would be enabled
after all communication was lost.
The following user(s) said Thank You: BigJohnT
Moderators: PCW, jmelson
Time to create page: 1.450 seconds
