7i76 Vin, Field power
04 May 2021 21:53 #207878 by rfrey
7i76 Vin, Field power was created by rfrey
I'm trying to understand the wiring in my system. I think:
- Field Power sets the voltage of the outputs and this is where the current drawn through the outputs will be sourced
- Vin provides power to local circuitry and must be >=8v. It can be joined to field power with a jumper if field power v is >8v.
Is that right? Why are there four terminals for field power?
04 May 2021 22:33 - 04 May 2021 22:34 #207889 by PCW
Replied by PCW on topic 7i76 Vin, Field power
That's correct. In addition field power sets the input thresholds.
Four terminals because its possible to have about 3-4 amps of continuous
output current (not good for one terminal) and in addition the pinout is
compatible with other devices (like the 7I84) that have field power divided
into two banks.
Last edit: 04 May 2021 22:34 by PCW.
04 May 2021 23:34 #207903 by rfrey
Replied by rfrey on topic 7i76 Vin, Field power
Great, thank you. I will monitor my output current and use those extra terminals if I get close to an amp, which will happen approximately never.
Moderators: PCWjmelson
Time to create page: 0.524 seconds
