Mesa 7i96 to spindle FWD/REV control
- mhd325ic
- Thank you received: 3
07 May 2021 04:22 #208179
by mhd325ic
Mesa 7i96 to spindle FWD/REV control was created by mhd325ic
I am use a 7i96 as 4-axis + PWM/DIR to control the spindle of a CNC milling machine. The CNC milling machine has a FWD/REV manual switch which I want to be replaced by two relays as suggested in Franco's youtube channel. The connection scheme is shown in the attached the picture.
Is the following connection from 7i96 to relay module correct?
Dir4+ ---- input of relay 1
Dir4- ---- input of relay 2
GND ---- S/S of relay module
Sorry for the novice question.
mhd325ic
mhd325ic
- BigJohnT
- Thank you received: 994
07 May 2021 11:55 - 07 May 2021 11:57 #208200
by BigJohnT
Replied by BigJohnT on topic Mesa 7i96 to spindle FWD/REV control
I would just use two outputs to control the spindle. PWM is Pulse Width Modulation. Step and Direction pins are 5v, not sure what voltage 4 is when flashed with pwm firmware.
You might want to try my 7i96 Configuration Tool .
From the 7i96 Manual:
JT
All step and direction outputs are buffered 5V signals that can drive 24 mA.
JT
Last edit: 07 May 2021 11:57 by BigJohnT.
- mhd325ic
07 May 2021 14:16 - 07 May 2021 15:08 #208220
by mhd325ic
Replied by mhd325ic on topic Mesa 7i96 to spindle FWD/REV control
I used your conconfiguration tool. Thanks very much and I get xyz axis working like a charm. Now I am thinking retrofit to 7i96 spindle control.
My milling machine's spindle needs 0-5v analog voltage to control the RPM. My plan is to convert PWM signal by a PWM2DC module in order to replace the potentiometer outputs. And DIR signal is used to control switchover relays.
Thanks pointing out that voltage 4 may not be 5V pulse.
What is the best approach to retrofit 7i96 to my spindle control?
Thanks in advance!
Mhd325ic
Thanks in advance!
Mhd325ic
Last edit: 07 May 2021 15:08 by mhd325ic.
- BigJohnT
07 May 2021 16:54 #208233
by BigJohnT
Here is a good post on a 7i96 spindle.
forum.linuxcnc.org/27-driver-boards/4176...ndle-with-7i96-tools
JT
JT
- mhd325ic
07 May 2021 18:39 #208241
by mhd325ic
Thank you for pointing to this post. This post and the mini lathe project are similar to my situation. It seems a good template for me to try and errors
After reading those posts, my plan is to use PMW4 for spindle variable voltage input and two 7i96 outputs for FWD/REV input.
Please point me out if I misunderstood the information. I will give it a try and posted back.
- BigJohnT
07 May 2021 22:58 #208264
by BigJohnT
Other post with same subject and question was deleted... no double posting it's too confusing.
JT
JT
- mhd325ic
12 May 2021 23:59 - 13 May 2021 01:04 #208676
by mhd325ic
I use a cheap PWM2DC module to convert PMW4 signal to 0-5v analogy voltage and an opto-isolated relay module is used to implement digital switchover. Without connect to the milling machine spindle control, the output voltage and FW / REV switch over works as expected when measured with a multimeter. The modules that I used are
and
However, it trigged GFCI breaker when it connect to the milling machine. Now I am guessing that the problem is PMW2DC module which don't have opto-isolator. Is my guess correct?
Last edit: 13 May 2021 01:04 by mhd325ic.
- mhd325ic
18 May 2021 20:08 #209390
by mhd325ic
Thanks for the help from you and PCW. I got the logic correct. With a SPINX1 card, now 7i96 can control spindle actions of setup speed and directions.
The problem that I am facing is that there are about 25% difference on linuxcnc rpm and spindle rpm.
Is there any way to set scale using 7i96 configuration tool?
- Thank you received: 5335
18 May 2021 21:42 #209415
Replied by PCW on topic Mesa 7i96 to spindle FWD/REV control
I dont know about the config tool but you can certainly change
the 7I96 PWM scale in the hal or ini file
- mhd325ic
19 May 2021 12:07 #209490
by mhd325ic
I did a calibration of actual rpm vs setted rpm in linuxcnc. The result is shown in the attached picture: in the setted rpm range of 0-2000, the spindle rpm of spindle is close to linear. If we can map the PWM duty range 0-0.8 to the spindle rpm 0-2500, the spindle speed control accuracy will be improved largely.
How to do it in the linuxcnc?
Time to create page: 0.144 seconds
