7i77 Servo Enable
5 years 5 months ago #208777 by Benb
Replied by Benb on topic 7i77 Servo Enable
The last suggestion by Chris@cnc is correct .
From the diagram, the inputs are sourcing type ie negative logic.
ENA0- => 37 (neg of PS)
ENA0+ => 3 (DI-0)
The following user(s) said Thank You: MrSpeaky
5 years 5 months ago #208793 by MrSpeaky
Replied by MrSpeaky on topic 7i77 Servo Enable
Ive found another picture in the manual that might help
5 years 5 months ago - 5 years 5 months ago #208801 by bevins
Replied by bevins on topic 7i77 Servo Enable
This is my suggestion. I always do it like this.
Put power on pins com on pin 37, + on pin 36,
net Servo-enable machine-is-on output-pin
Coneect a relay to ouput pin and run pin 37 to one side of N.O relay and other side to pin 3.
That should enable your drive. I always use mesa boards like this and never had an issue.
Last edit: 5 years 5 months ago by bevins.
Moderators: PCW, jmelson
Time to create page: 0.050 seconds
