5i25 / 7i76 / 7i85 - swapping Dsub connectors over?
14 May 2021 16:49 #208820 by Muzzer
As part of my system build, I've stripped down the bench top setup and am getting the components ready to go into the actual cabinet. I had the system (lathe) working with my 7i76 on the main D connector of the 5i25 and the 7i85 on a second D connector coming off the pin header of the 5i25 via a ribbon cable.
Due to the way the boards need to be wired up in the cabinet, I've ended up swapping the 7i76 and 7i85 across, so that the 7i85 is now on the main D connector etc. Obviously this won't simply work as before but I'm not sure how to reconfigure it. Do I need to change the bitfile or run some sort of setup to point the 5i25 to the new arrangement of the 7i76 and 7i85?
Hopefully I haven't created a big job for myself here by swapping them over!
14 May 2021 16:56 #208822 by PCW
You would need a 5I25_7i85_7i76.bit bitfile rather than the standard
5i25_7i76_7i85 bitfile. Is that a 7I85 or 7I85S?
14 May 2021 17:01 #208824 by Muzzer
It's the straight 7i85
14 May 2021 17:45 #208828 by PCW
File Name: 5i25_85_76.zip
File Size:109 KB
14 May 2021 17:51 - 14 May 2021 17:52 #208830 by Muzzer
Brilliant! Many thanks for the prompt and helpful reply. I'll have a go at that later.
I didn't think of this potential complication until after I'd mounted the boards!
Last edit: 14 May 2021 17:52 by Muzzer.
15 May 2021 10:52 - 15 May 2021 10:53 #208902 by Muzzer
I seem to have reflashed it OK but after a restart when I try to run LinuxCNC, I get
./hallib/Bantam_v1.hal:27: Pin 'hm2_5i25.0.7i76.0.0.input-00' does not exist
Do I need to rename some of the nets relating to the 7i76 address in the HAL file now? Although I don't have all the inputs connected up again yet, I don't think it's even getting to that stage.
File Name: linuxcnc.report.txt
File Size:7 KB
File Name: Bantam_v1_...5-15.hal
File Size:9 KB
Last edit: 15 May 2021 10:53 by Muzzer.
15 May 2021 12:02 #208906 by tommylight
Do you have VField power going to 7i76?
15 May 2021 13:12 #208910 by Muzzer
It wasn't but I reconnected it (CR2 now comes on) and restarted. Now I am back in play, so the changes seem to have been made successfully. Thanks for your patience - it had to be simple!
Back to the cabinet build again....
Moderators: PCW, jmelson
Time to create page: 0.121 seconds
