fieldbus systems
- vre
- Thank you received: 17
17 May 2021 19:55 #209265
by vre
fieldbus systems was created by vre
Hello
Linuxcnc supports fieldbus systems like devicenet/interbus/profibus/canopen/ethercat ?
For example to use i/o modules from wago/beckhoff ?
- aleksamc
- Thank you received: 67
17 May 2021 20:08 #209267
by aleksamc
Replied by aleksamc on topic fieldbus systems
As I know linuxcnc can use ethercat.
Some info here
- Roiki
- Thank you received: 19
18 May 2021 13:52 #209352
by Roiki
Replied by Roiki on topic fieldbus systems
Ethercat only since none of them have easily accessible master systems for people to work on. They always cost an arm and a leg.
- vre
19 May 2021 10:00 #209474
by vre
Replied by vre on topic fieldbus systems
ethercat does not needs special hardware on master (pc side)?
Ethernet port is enough ?
Seems good option...
- Roiki
20 May 2021 15:27 #209659
by Roiki
It needs a realtime Kernel, a software stack and compatible Ethernet drivers. You can either do this in a separate card with a dedicated processor and API or entirely in software like linuxcnc does.
Time to create page: 0.307 seconds
