- Thank you received: 5
andypugh wrote: Is the interface step/dir on GPIO pins, or does it have some higher-level interface to on-hat logic?
Twizzlermill wrote: This is the thing:
wiki.protoneer.co.nz/Raspberry_Pi_CNC .
Right. That is running GRBL on the hat. GRBL is roughly equivalent to LinuxCNC and there is no way to use both GRBL and LinuxCNC in a single system (and it makes absolutely no sense to do so).
You might want to search this forum for "Remora". That might be close to what you want.
Or, the docs here: remora-docs.readthedocs.io/en/latest/
Aaroncnc wrote: the mesa card will not drive a motor directly.
It will make the signal to go to the motor driver and that driver will drive the motor.
Best thing to do is make a list of hardware you have or are going to buy and we can try and help you with what will work or wont.
What I have/want:
1.: A Raspberry Pi 4 as a computer (with all the other stuff of course).
2.: 4 JMC Closed Loop Stepper motors(Model IHSS60-36-30-21-38); the y-axis will need two.
