mesacard wont start
- anfänger
- Thank you received: 271
15 Jun 2021 18:23 #212136
by anfänger
mesacard wont start was created by anfänger
hi,
my mesa card is making troule
when i try to power up i get this error essage.
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: INFO: Hardware address (MAC): ff:ff:ff:ff:ff:ff
hm2_eth: Unrecognized ethernet board found: � -- port names will be wrong
hm2_eth: discovered �
hm2: invalid llio name passed in (contains non-printable character)
board fails HM2 registration
hm2_eth: in hm2_eth_reset
hm2_eth: rtapi_app_main: Invalid argument (-22)
./hallib/core_igor.hal:7: waitpid failed /usr/bin/rtapi_app hm2_eth
./hallib/core_igor.hal:7: /usr/bin/rtapi_app exited without becoming ready
./hallib/core_igor.hal:7: insmod for hm2_eth failed, returned -1
but it used to work for the last years. i can pingand after some restarting it will start to work.
any ideas? what that might be? its a 7i92
thanks patrick
thanks patrick
- Thank you received: 5335
15 Jun 2021 18:54 - 15 Jun 2021 19:09 #212137
Replied by PCW on topic mesacard wont start
Sounds like a bad EEPROM, the MAC address indicates that
the EEPROM MAC address was read as 0xFFFFFFFFFFFF
which means either there is a reading error or the chip has
lost its stored data.
I have seen occasional issues with MicroChip EEPROMs and low
temperatures but don't think I have ever seen the newer ST EEPROMs fail.
You might check that there is no board contamination or metal chips
Last edit: 15 Jun 2021 19:09 by PCW.
- anfänger
16 Jun 2021 07:49 #212183
by anfänger
Replied by anfänger on topic mesacard wont start
Thank I‘ll check this evening. It can’t have completely lost its data.
Cause after some tries it works. Same was yesterday after half 15 minutes of switching and pinging it fired up. Ans I could mill my part without a problem.
- Thank you received: 7501
16 Jun 2021 11:53 #212193
Replied by tommylight on topic mesacard wont start
Do you have another 5V power supply?
- anfänger
16 Jun 2021 13:52 #212201
by anfänger
This worked for years, but yes I will give it at try if cleaning wont help.
I had the issue with the current card
Thanks for the suggestion
- anfänger
16 Jun 2021 17:08 #212207
by anfänger
vacuumed the parts and bumped up the voltge now it seam to work again.
thanks for the help
thanks for the help
The following user(s) said Thank You: arvidb, tommylight
Time to create page: 0.535 seconds
