Raspberry Pi 3B and Mesa 7i90HD
- drummond
- Thank you received: 5
27 Jun 2021 20:29 #213049
by drummond
Raspberry Pi 3B and Mesa 7i90HD was created by drummond
Why a 3B? I happen to have one
Why the 7i90HD? It seems like 7C81's are out of stock right now.
So, questions:
Can I use this:
store.mesanet.com/index.php?route=produc...oduct&product_id=355
will it fit the 7i90 or is it only intended for use on 7c80 and 7c81?
I have read that it is probably better to use 714TAs on the 26 pin headers as a form of voltage protection. Initially the intention is to feed a Gecko G540 from one of the headers and nothing more, is a 714TA needed for this?
Thanks.
So, questions:
Can I use this:
Thanks.
- Thank you received: 7501
27 Jun 2021 21:36 #213054
Replied by tommylight on topic Raspberry Pi 3B and Mesa 7i90HD
Moved to "driver boards".
- Thank you received: 5335
28 Jun 2021 01:45 #213070
Replied by PCW on topic Raspberry Pi 3B and Mesa 7i90HD
Yes, you could use a 7I90 but the cabling/mechanical connections
are a bit awkward. You can connect a 7I90 to a G540 electrically
since a G540 functions as a BreakOut Board (BOB) but again its
not a direct mechanical connection because of the connector
differences. The 7C81 should be available fairly soon so I would
wait for that.
wait for that.
- drummond
28 Jun 2021 02:59 #213079
by drummond
Replied by drummond on topic Raspberry Pi 3B and Mesa 7i90HD
Thanks Peter,
That approach would be much easier.
When do you think the 7C81's might be available?
29 Jun 2021 19:59 #213263
Available now
- drummond
03 Jul 2021 17:16 #213576
by drummond
Thanks Peter,
The 3B went to another project, but I have decided to acquire a 4 to play with. This opens up some other possibilities, I think I should start another thread for those.
Time to create page: 0.097 seconds
