It may be that the chargepump output doesn't have enough
high level drive for the G540. You might try jumpering the 5I25
for 3.3V compatibility on P3, This will provide a bit more high side drive.
W3 jumper is in the UP position (5V tolerance mode enabled). I had it that way when things were working under 2.5.3. But I can give it a whirl tomorrow and see if it does anything.
