Driving a charge pump with a Mesa 5i25 stepgen
4 years 8 months ago #234128 by PCW
setp [HMOT](CARD0).stepgen.04.position-scale 10000
setp [HMOT](CARD0).stepgen.04.step_type 2
setp [HMOT](CARD0).stepgen.04.control-type 1
setp [HMOT](CARD0).stepgen.04.maxaccel 0
setp [HMOT](CARD0).stepgen.04.maxvel 0
setp [HMOT](CARD0).stepgen.04.velocity-cmd 0.25
This will generate a 2500 Hz square wave, not 10 KHz
For clarity, I would probable set
setp [HMOT](CARD0).stepgen.04.velocity-cmd 10000
for a 10 KHz chargepump signal
4 years 8 months ago #234157 by dbotos
Peter,
Thanks.  I changed those two values and no luck.
Do I need to add a line that adds the charge pump to the base thread?  Section 14.10.2.9 of the 2.8.2 documentation says:
"The Charge Pump should be added to the base thread function."
4 years 8 months ago #234160 by PCW
No, the base thread is not needed for hardware stepgens
4 years 8 months ago #234174 by dbotos
Let me see if I understand this correctly:
position-scale = (distance) / (# of steps)
Divide the numerator and denominator of the right side by unit time:
position-scale = (distance / s) / (# steps / s)
If position-scale = 1, then:
(distance / s) = (# steps / s)
So a velocity command (distance / s) should generate a waveform of step pulses with a frequency (in Hz) equal to the value of the velocity commanded.
Is the charge pump expecting a 50% duty cycle wave?  Should the steplen and stepspace be bumped up to 50,000 ns each?
T = 50,000 ns + 50,000 ns = 100,000 ns
f = 1 / T = 1 / (0.000 100 000) = 10,000 Hz
4 years 8 months ago #234177 by PCW
The quadrature output mode (mode 2) insures 50% duty cycle
(the step time and step space need to be set to small
values so they do not limit the step rate)
4 years 8 months ago #234179 by dbotos
Ah, okay.
Am I missing some sort of virtual connection between the stepgen.04 output and pin 16 of the 5i25 DB25 connector (P3)?
Moderators: PCW, jmelson
Time to create page: 0.080 seconds
