Network Issue with Mesa and Wifi
06 Jul 2021 10:41 #213844 by Ritterchen
Network Issue with Mesa and Wifi was created by Ritterchen
Hey together,
I set up my Mesa Card accordingly to this how-to here forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
However I have still wired issues with reaching some websites (linuxcnc.org) while others work perfectly fine (LinuxCNC Forum, Google)
The checkbox of "Use this connection only for resources on its network" is enabled.
Someone has a clue what could be the issue here?
All the best
Fritz
06 Jul 2021 16:15 #213870 by PCW
Replied by PCW on topic Network Issue with Mesa and Wifi
What does the command
ip a
report?
  • Moderator
  • Moderator
06 Jul 2021 16:58 #213873 by tommylight
Replied by tommylight on topic Network Issue with Mesa and Wifi
Not an issue on your end, LinuxCNC site might be under maintenance or something, so if everything else works you're good.
06 Jul 2021 18:17 #213879 by scotth
Replied by scotth on topic Network Issue with Mesa and Wifi
I'm having a problem with this also. I can use the internet until I start the 7i76, after that I have to restart the system for Internet.
File Name: ipatext.txt
File Size:1 KB
06 Jul 2021 18:29 #213880 by PCW
Are you using wicd?
Its known to cause issues with multiple connections
06 Jul 2021 18:58 - 06 Jul 2021 19:33 #213883 by scotth
I'm on 2.9.0 I don't know if I'm using wicd.
I did not notice the Wi-Fi, I'm running 2 Ethernet cards. I gave up on Wi-Fi at 2.7.
Last edit: 06 Jul 2021 19:33 by scotth.
06 Jul 2021 19:39 #213888 by PCW
If you started with the standard 2.8.0 ISO you will have WICD installed
It needs to be replaced with Network Manager as WICD breaks configurations with multiple interfaces
06 Jul 2021 21:00 - 06 Jul 2021 21:09 #213893 by Ritterchen
Replied by Ritterchen on topic Network Issue with Mesa and Wifi
I'm running Network Manager. While I did the test I tested at the same time on another system, so I assume it should not be related to maintenance.
The output of ip a looks as following:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 00:23:24:7c:26:7d brd ff:ff:ff:ff:ff:ff
    inet 10.10.10.11/24 brd 10.10.10.255 scope global eno1
3: wlx00c0ca649806: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 00:c0:ca:64:98:06 brd ff:ff:ff:ff:ff:ff
    inet 192.168.178.60/24 brd 192.168.178.255 scope global noprefixroute wlx00c0ca649806
    inet6 2003:c6:371a:7e00:6511:37a1:5c6b:762b/64 scope global dynamic noprefixroute
       valid_lft 7190sec preferred_lft 1790sec
    inet6 fe80::d8e8:204d:6d51:4803/64 scope link noprefixroute
Last edit: 06 Jul 2021 21:09 by Ritterchen.
06 Jul 2021 21:56 #213905 by PCW
That actually looks OK, I would guess the problem is elsewhere
Moderators: PCW, jmelson
