Need help with 7i96 card that stoped working.
- oficinerobotica
- Thank you received: 12
26 Jul 2021 18:51 #215974
by oficinerobotica
Need help with 7i96 card that stoped working. was created by oficinerobotica
Please some kind soul help to understand if my card went bust or it can be recovered.
The problem is that the card was working then all of a sudden stopped with all the lights off. Changing the usb charger( I know I need a proper power supply) relighted the card but initially I couldn't ping it. After a few power cycles I was able to ping the card that is on 10.10.10.10 but always got an error when tring to test a axis in pncconf.
I sometimes got the solid red INIT led and searching the forum I reflashed the card with mesaflash.
Now the card can be pinged and axis starts whibout any errors but the steppers won't move. When Axis starts cr1 to cr4 leds stay solid green on. When Axis is closed the INIT led turns solid red.
This is how far I can get. If someone can help me I would be forever grateful as these cards are costly to have them here in Europe.(250€ after tax and shipping)
- oficinerobotica
26 Jul 2021 18:58 #215975
by oficinerobotica
Replied by oficinerobotica on topic Need help with 7i96 card that stoped working.
Some additional info.
If I do mesaflash --device 7i96 --verbose I get:
No 7I96 board found
Instead, this is the output of mesaflash --device 7i96 --addr 10.10.10.10 --readhmid
BoardName : MESA7I96
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: PWM
There are 1 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: StepGen
There are 8 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: QCount
There are 2 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: SSR
There are 1 of SSR in configuration
Version: 0
Registers: 2
BaseAddress: 7D00
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for TB3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort None
14 1 IOPort None
2 2 IOPort None
15 3 IOPort None
3 4 IOPort None
16 5 IOPort None
4 6 IOPort None
17 7 IOPort None
5 8 IOPort None
6 9 IOPort None
7 10 IOPort None
8 11 IOPort SSR 0 Out-00 (Out)
9 12 IOPort SSR 0 Out-01 (Out)
10 13 IOPort SSR 0 Out-02 (Out)
11 14 IOPort SSR 0 Out-03 (Out)
12 15 IOPort SSR 0 Out-04 (Out)
13 16 IOPort SSR 0 Out-05 (Out)
IO Connections for TB1/TB2
1 17 IOPort StepGen 0 Step/Table1 (Out)
14 18 IOPort StepGen 0 Dir/Table2 (Out)
2 19 IOPort StepGen 1 Step/Table1 (Out)
15 20 IOPort StepGen 1 Dir/Table2 (Out)
3 21 IOPort StepGen 2 Step/Table1 (Out)
16 22 IOPort StepGen 2 Dir/Table2 (Out)
4 23 IOPort StepGen 3 Step/Table1 (Out)
17 24 IOPort StepGen 3 Dir/Table2 (Out)
5 25 IOPort StepGen 4 Step/Table1 (Out)
6 26 IOPort StepGen 4 Dir/Table2 (Out)
7 27 IOPort QCount 0 Quad-A (In)
8 28 IOPort QCount 0 Quad-B (In)
9 29 IOPort QCount 0 Quad-IDX (In)
10 30 IOPort SSerial 0 RXData0 (In)
11 31 IOPort SSerial 0 TXData0 (Out)
12 32 IOPort SSerial 0 TXEn0 (Out)
13 33 IOPort SSR 0 AC Ref (Out)
IO Connections for P1
1 34 IOPort PWM 0 PWM (Out)
14 35 IOPort None
2 36 IOPort StepGen 5 Step/Table1 (Out)
15 37 IOPort None
3 38 IOPort StepGen 5 Dir/Table2 (Out)
16 39 IOPort None
4 40 IOPort StepGen 6 Step/Table1 (Out)
17 41 IOPort None
5 42 IOPort StepGen 6 Dir/Table2 (Out)
6 43 IOPort StepGen 7 Step/Table1 (Out)
7 44 IOPort StepGen 7 Dir/Table2 (Out)
8 45 IOPort None
9 46 IOPort None
10 47 IOPort None
11 48 IOPort QCount 1 Quad-A (In)
12 49 IOPort QCount 1 Quad-B (In)
13 50 IOPort QCount 1 Quad-IDX (In)
No 7I96 board found
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: DPLL
Version: 0
Registers: 7
BaseAddress: 7000
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: PWM
Version: 0
Registers: 5
BaseAddress: 4100
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: QCount
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: SSR
Version: 0
Registers: 2
BaseAddress: 7D00
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
1 0 IOPort None
14 1 IOPort None
2 2 IOPort None
15 3 IOPort None
3 4 IOPort None
16 5 IOPort None
4 6 IOPort None
17 7 IOPort None
5 8 IOPort None
6 9 IOPort None
7 10 IOPort None
14 35 IOPort None
15 37 IOPort None
16 39 IOPort None
17 41 IOPort None
8 45 IOPort None
9 46 IOPort None
10 47 IOPort None
- Thank you received: 5332
26 Jul 2021 19:10 - 26 Jul 2021 19:11 #215977
Replied by PCW on topic Need help with 7i96 card that stoped working.
I would first start with a decent 5V power supply.
Most errors look power supply related.
(its expected to have the INIT led light on exit from LinuxCNC, this shows that the watchdog bit)
Last edit: 26 Jul 2021 19:11 by PCW.
The following user(s) said Thank You: oficinerobotica
- oficinerobotica
26 Jul 2021 19:18 #215978
by oficinerobotica
Thank you. I ordered a MeanWell RS-25-5 25W 5V 5A industrial power supply and I will update you when it arrives.
- oficinerobotica
29 Jul 2021 06:25 #216190
by oficinerobotica
So the power supply arrived but still no luck at getting steps.
I managed to get an output from:
mesaflash --device 7i96 --addr 10.10.10.10 --verbose
ETH device 7I96 at ip=10.10.10.10
Communication:
transport layer: ethernet IPv4 UDP
ip address: 10.10.10.10
mac address: 00:60:1B:16:03:24
protocol: LBP16 version 3
Board info:
Flash size: 16Mb (id: 0x14)
Connectors count: 3
Pins per connector: 17
Connectors names: TB3 TB1/TB2 P1
FPGA type: 6slx9tqg144
Number of leds: 4
Board firmware info:
memory spaces:
0: HostMot2 (registers, RW, 32-bit) [size=64K]
1: KSZ8851 (registers, RW, 16-bit)
2: EtherEEP (EEPROM, RW, 16-bit) , page size: 1, erase size: 1
3: FPGAFlsh (flash, RW, 32-bit) [size=16M], page size: 256, erase size: 65536
4: Timers (memory, RW, 16-bit)
6: LBP16RW (memory, RW, 16-bit)
7: LBP16RO (memory, RO, 16-bit)
[space 0] HostMot2
[space 2] Ethernet eeprom:
board name: 7I96
user leds: eth debug
[space 3] FPGA flash eeprom:
flash size: 16Mb (id: 0x14)
[space 4] timers:
uSTimeStampReg: 0x3B80
WaituSReg: 0x0000
HM2Timeout: 0x0000
[space 6] LBP16 control/status:
packets received: all 63473, UDP 63352, bad 0
packets sent: all 32629, UDP 32623, bad 0
parse errors: 0, mem errors 0, write errors 0
error flags: 0x0000
debug LED ptr: 0x0008
scratch: 0x0000
[space 7] LBP16 info:
board name: 7I96
LBP16 protocol version 3
board firmware version 17
IP address jumpers at boot: fixed from EEPROM
Communication:
Board info:
Connectors count: 3
Number of leds: 4
memory spaces:
[space 0] HostMot2
board name: 7I96
[space 4] timers:
WaituSReg: 0x0000
HM2Timeout: 0x0000
error flags: 0x0000
scratch: 0x0000
board name: 7I96
29 Jul 2021 13:37 #216218
Do you get any errors from LinuxCNC?
You might measure the step voltage with a meter both before LinuxCNC is launched and when LinuxCNC is running to see if you have about 5V in one case and about 0V in the other.
- oficinerobotica
29 Jul 2021 14:21 #216223
by oficinerobotica
I measured the voltage between DIR+ and DIR- on the board before and after starting LinuxCNC. In both cases I get 4.8V . In fact I measured the voltage powering only the card and I always get 5V. I also get no voltage variation when measuring between DIR+ and DIR- .
Is it normal to always have 5V between those terminals?
29 Jul 2021 14:28 #216226
It is but it should change if you jog in different directions
- oficinerobotica
29 Jul 2021 14:42 #216229
by oficinerobotica
Now the big question is this; is it possible that a current spike has fried only the step generation part of the board or it usually makes the whole thing unusable? This setup was working correctly so I'm tending to exclude wiring problems.
By the way, thank you so much for the help.
29 Jul 2021 14:51 #216230
Are you sure you don't have a watchdog bite? (red LED when LinuxCNC is running)
That would cause inability to control the outputs
If you don't have a watchdog bite and jogging both directions does not change the DIR pins, that suggests that the 5V powered buffer chips have been damaged somehow
(perhaps a spike in the 5V supply)
Time to create page: 0.323 seconds
