Warning: Need latest Mesaflash version - -EEPROM corruption
02 Aug 2021 20:45 #216747 by PCW
Recent Mesa 7I92M's 7C80's and 7C81's use a different FPGA EEPROM
And must be programmed with the latest Mesaflash or memory corruption
is possible.
The latest mesaflash is:
github.com/LinuxCNC/mesaflash
03 Aug 2021 09:44 #216798 by andypugh
Do we need to build a new package for the repository?
ie, does "sudo apt-get install mesaflash" currently provide the correct level?
Does the ISO contain the correct version?
03 Aug 2021 12:57 #216813 by BigJohnT
I tried to update the changelog file for the mesaflash repository so you could tell if your running the latest version or not but I don't have push rights to mesaflash for some reason.
JT
03 Aug 2021 14:16 #216832 by PCW
The fix for 32 Mbit EEPROMs was pushed on May 27 so if the ISO/package was made after that its ok. There's also a bug fix on June 29 but its not a critical bug, just a bug in the added "--dbname" feature.
JT: I'm surprised the push rights aren't the same for Mesaflash and LinuxCNC
04 Aug 2021 13:16 #216906 by andypugh
I guess that the ISO would have picked up the current .deb from the main repo. I don't know what the path is from the Mesaflash github to the LinuxCNC repository, but that seems to be 3.4.0 from 2020-05-22
www.linuxcnc.org/dists/buster/base/binary-amd64/
So, we are not distributing the correct version.
07 Aug 2021 23:24 #217163 by cakeslob
To clarify on this, do you mean recently manufactured cards have an eeprom hardware revision/alternate eeprom or those cards in general have different eeprom?
07 Aug 2021 23:48 - 07 Aug 2021 23:49 #217166 by PCW
Only recent versions of those cards require the latest Mesaflash
( They have 32 Mbit EEPROMs rather than 8 or 16 Mbit )
Last edit: 07 Aug 2021 23:49 by PCW.
Moderators: PCW, jmelson
Time to create page: 0.099 seconds
