Mesa 7i76E and JMC Steppers – Edge up or down?
- Twizzlermill
- Thank you received: 5
09 Aug 2021 19:09 #217326
by Twizzlermill
Mesa 7i76E and JMC Steppers – Edge up or down? was created by Twizzlermill
Hello,
I expect this to be a super niche problem, but maybe someone dealt with it already or has a hint for me, how I could figure this out.
On the JMC Stepper Driver, there's DIP switches and one of them allows me to choose between rising and falling edge. What I determined by now is that this refers to the way signals are interpreted, namely whether an electric signal is interpreted as a "1" or or a "0". Thing is, I don't know which is the right choice and how to even determine that. Apparently, the wrong choice may lead to lost steps, but frankly, my machine is likely to be so imprecise that I'm not sure how to notice it until I meet a situation in which it might've mattered.
So, any ideas?
TIA
So, any ideas?
TIA
- Thank you received: 5335
09 Aug 2021 19:46 #217332
Replied by PCW on topic Mesa 7i76E and JMC Steppers – Edge up or down?
Assuming that "rising-edge: means opto-coupler LED illuminated
I would use rising edge and standard single ended connections:
Drive Step+/Dir+ to +5V
7I76E Step-/Dir- to drive Step-/Dir-
The following user(s) said Thank You: Twizzlermill
- rollfree
- Thank you received: 11
10 Aug 2021 22:05 - 10 Aug 2021 22:07 #217430
by rollfree
Replied by rollfree on topic Mesa 7i76E and JMC Steppers – Edge up or down?
Are you sure? According to me "rising edge" means, that puls is active in log. H.
So when set to "rising edge", connect 7i76e Step+ to Step+ on driver, Step- on driver to GND.
When "falling edge", connect 7i76e Step- to Step- on driver, Step+ on driver to +5V.
Signal Dir the same way.
Last edit: 10 Aug 2021 22:07 by rollfree.
11 Aug 2021 16:53 #217561
Yes, I'm pretty sure.
"rising edge" is not as simple when dealing with differential inputs.
For example if I have a standard step drive and I connect STEP+ to +5V
and STEP- to the controller. the controller must output active low step pulses,
even though the drive is set for rising edge. In my experience the active
edge is almost always the one that illuminates the optocoupler LED
If a drive with optocouler inputs is set for falling edge, I would expect it to
step when the optocoupler loses drive.
- rollfree
11 Aug 2021 18:46 #217567
by rollfree
Yes, you are right. Both variants are possible. My mistake.
For "rising edge":
or
For "rising edge":
or
Time to create page: 0.069 seconds
