Simulate a mesa 7i96 (solved)
- Clive S
- Thank you received: 486
10 Nov 2021 12:06 #225966
by Clive S
Simulate a mesa 7i96 was created by Clive S
Is it possible to simulate a Mesa 7i96 with a Arduino etc so as to be able fool the PC into thinking it has a 7i96 connected.
This is to be able to start the QTplasmaC gui when not at the machine control box with the actual card.
- nkp
- Thank you received: 39
10 Nov 2021 12:19 #225972
by nkp
Replied by nkp on topic Simulate a mesa 7i96
Arduinо is not needed, you can just write a component.
- Thank you received: 4152
10 Nov 2021 12:25 #225974
Replied by rodw on topic Simulate a mesa 7i96
Yeh, just use showpin and create a component with the same pins that does nothing.Arduinо is not needed, you can just write a component.
- Clive S
10 Nov 2021 13:13 #225981
by Clive S
Replied by Clive S on topic Simulate a mesa 7i96
I have never written a component, so stumped
- nkp
10 Nov 2021 13:24 - 10 Nov 2021 13:25 #225982
by nkp
Send me configuration files (archive of the entire folder), I will write a component for you.
(nkp216 gmail)
(nkp216 gmail)
Last edit: 10 Nov 2021 13:25 by nkp.
- Clive S
10 Nov 2021 13:33 #225984
by Clive S
Thanks I have sent you an email
(nkp216 gmail)
- Thank you received: 7491
10 Nov 2021 16:03 #225998
No, make it move the drapes, make a coffee, mow the lawn ....
Replied by tommylight on topic Simulate a mesa 7i96
- Clive S
11 Nov 2021 12:25 #226096
by Clive S
this is now solved
Replied by Clive S on topic Simulate a mesa 7i96 (solved)
Just like to make a big thankyou to nkp216 for writing a component for me.
(nkp216 gmail)
this is now solved
- Tesremos
- Thank you received: 10
09 Feb 2023 08:44 #264113
by Tesremos
Replied by Tesremos on topic Simulate a mesa 7i96 (solved)
whats the chance of getting a copy of this component. so i can use it as a template for other mesa hardware?
Time to create page: 0.136 seconds
