ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
27 Feb 2022 16:23 #235928 by jmelson
First of all running as root is a really bad idea.
Why ?
Many peoples tell me "it is bad idea", but nobody can tell why ...
Linux is not windows, it has it's own way of doing things ... not important.
Running as a normal user in case of /infection/attack/mess up/exploit/ there is no easy way of installing additional code and make it run in Linux or have access to system /files/memory/hardware/, while running as Root the doors are already opened.
I am not good at explaining stuff, but in general, it is not a good idea to run as root although chances are very low that something will actually happen if you do not click and run unknown stuff/links/software/
I had a "root kit" installed on one of my systems decades ago.  It added malicious code to a number of executables on my system.  Once, when I logged in remotely and needed to do some system task, then that executable took advantage of the higher priviledge and wrecked the whole system.  It was a big security wake-up call.  and, of course, a simple typo can have disasterous effects when you are in su mode all the time.
Jon
27 Feb 2022 17:31 #235931 by tuxcnc
Litex supports at least V8.0 of the 5A-75B board.
The colorlight_5a_75b.py from romanetz (THANK YOU!) can also be used on a 5A-75B V8.0 board when you change near line 348
platform = colorlight_5a_75b.Platform()
to
platform = colorlight_5a_75b.Platform(revision="8.0")
This will change the pinout for ethernet etc. to V8.0
Colorcnc not yet working but I can connect to the board.
Thanks.
Now I'm fighting with nextpnr-ecp5 installation.
The colorlight_5a_75b.py already works.
  • 's Avatar
  • Visitor
  • Visitor
27 Feb 2022 17:36 - 27 Feb 2022 17:38 #235932 by
Installation of litex and oss-cad-suite
First remove your current installation, the way you do it is up to you
Litex
mkdir ~/LiteX
cd ~/Litex
wget https://raw.githubusercontent.com/enjoy-digital/litex/master/litex_setup.py
chomd +x litex_setup.py
./litex_setup --init --install --user
OSS-CAD-SUITE
mkdir ~/Downloads/oss-cad-suite
cd ~/Downloads/oss-cad-suite
wget https://github.com/YosysHQ/oss-cad-suite-build/releases/download/2022-02-27/oss-cad-suite-linux-x64-20220227.tgz
sudo tar -xvf oss-cad-suite-linux-x64-20220123.tgz -C /usr/local/
Add the following to ~/.profile
# set PATH so it includes oss-cad-suite
if [ -d "/usr/local/oss-cad-suite/bin" ] ; then
PATH="/usr/local/oss-cad-suite/bin:$PATH"
fi
Logout and log back in.
Last edit: 27 Feb 2022 17:38 by .
  • 's Avatar
  • Visitor
  • Visitor
27 Feb 2022 17:41 #235933 by
The above post install everything required to build with litex.
As for root, as it is a valid discussion.
www.vultr.com/docs/why-use-sudo-instead-of-logging-in-as-root/
27 Feb 2022 19:51 #235944 by tuxcnc
[b]OSS-CAD-SUITE
[code]mkdir ~/Downloads/oss-cad-suite
[b]Add the following to ~/.profile
[code]# set PATH so it includes oss-cad-suite
fi
[/code][/b][/code][/b]
Thanks.
Well, install 433 MB is overkill, but works.
The Litex not works for me. Has all files, but python can't find.
I tried run script and collect missing files to work directory.
I wonder, the script need only four directories from Litex installation : litedram  liteeth  liteiclink  litex  litex_boards
I tried on fresh Xubuntu 20.10.
You must first :
tar -xvf oss-cad-suite-linux-x64-20220227.tgz -C /usr/local/
apt update
apt install python3-pip
pip3 install migen
cd colorlight-directory
./colorlight_5a_75b.py
cd build/colorlight_5a_75b/gateware
sh build_colorlight_5a_75b.sh.
<apt install python3-pip> installs all dependences including python3,
I don't know is my file working, because I haven't programmer.
Chinaman sent to me Altera not Lattice...
But you can test it.
github.com/tuxcnc/tuxcnc/blob/master/colorcnc-directory.tar.bz2
  • 's Avatar
  • Visitor
  • Visitor
27 Feb 2022 21:00 #235947 by
If you follow my instructions, you don’t need to install migen as a seperate item.
What is the vendor and product id of your programmer ?
openfpgaloader may be able to use it, which is included in the oss-cad-suite. Yes the download is big but it is far easier than having to build all the parts to have a full suite of programs to build the bit file.
I have done it both ways, after finding out the Debian yosys packages were too old.
  • 's Avatar
  • Visitor
  • Visitor
27 Feb 2022 21:06 #235948 by
Btw adding —build to the colourlight_5a_75b.py command will run the build script as well. If it fails it is usually because stepgen.v isn’t in build/gateware directory.
27 Feb 2022 22:23 #235949 by tuxcnc
I ran colorlight_5a_75b.py before set path, probably this is explanation.
The programmer is still in bag, because I have dispute with seller.
I don't know vendor and id, but have photo :
  • 's Avatar
  • Visitor
  • Visitor
27 Feb 2022 23:02 #235954 by
I have a feeling that might work, I use an Altera USB Blaster clone works fine with openfpgaloader, which is included with oss-cad-suite
28 Feb 2022 22:11 #236039 by TOLP2
At this moment I'm trying to make the idea of ColorCNC more flexible and expandable to more ColorLight cards. Therefore I started LiteX-CNC based on the contributions.
Trying to:
- configure the card by a JSON file (click-and-program);
- firmware split over multiple files for better readability and expansion with new functions;
- supports all ethernet FPGA cards which are supported by LiteX.
It is still work in progress (only GPIO out is finished at this moment) and not tested as my card is not yet in.
The repository can be found here: github.com/Peter-van-Tol/LiteX-CNC
The following user(s) said Thank You: kwarup, , svb
Moderators: PCW, jmelson
Time to create page: 0.528 seconds
