Create a FPGA board for raspberry
4 years 8 months ago - 4 years 8 months ago #235081 by PCW
If you take the pinout file that D.L. provided and edit it to:
1. Add your additional encoders, sserial ports and PWMgens
2. Remove the inmux (actually not sure here if your hardware include the muxes or not)
Either D.L or I can take that new pinout and make a bitfile that
matches your hardware.
Last edit: 4 years 8 months ago by PCW.
4 years 8 months ago #235115 by D.L.
1. Additional encoders, sserial ports and PWMgens not needed, the pinout was created for the current scheme .
2. InMux module needed, in the current scheme used multiplexing(ICs: U1-U4) input signals IN0-IN23.
4 years 8 months ago #235156 by Boaschti
Much Thanks!!!
That looks nice. Outpus are working. I tested with  7c80v2.zip .
Inmux is present you are right.
The second PWM isn't listed in hm2_7c80-0-pwmgen. Is it ok?
If I see a value like 0.65 at hm2_7c80.0.pwmgen.00.value I should measure a PWM Signal on IO18? Am I right?
Where can i find the encoders in HAL Configuration?
4 years 8 months ago - 4 years 8 months ago #235163 by D.L.
hm2_7c80.0.pwmgen.00: first pwmgen, outputs 18(PWM), 19(/Enable)
hm2_7c80.0.pwmgen.01: second pwmgen, output 37(PWM)
For enable PWMgen need set hm2_7c80.0.pwmgen.00.value and hm2_7c80.0.pwmgen.00.enable=true
hm2_7c80.0.encoder.00: 15(A), 16(B ), 17(IDX)
hm2_7c80.0.encoder.01: 38(A), 39(B ), 40(IDX)
hm2_7c80.0.encoder.02: 48(A), 49(B ), 50(IDX)
hm2_7c80.0.encoder.03: 51(A), 52(B ), 53(IDX)
Hosmot2 manual, may be useful: linuxcnc.org/docs/html/man/man9/hostmot2.9.html
Last edit: 4 years 8 months ago by D.L..
4 years 8 months ago - 4 years 8 months ago #235166 by D.L.
Boaschti, may be you want pwmgen with dual pwm outputs(up-down mode)?
4 years 8 months ago #235239 by Boaschti
The solution was to edit config string: num_encoders and num_pwmgen.
Much thanks for helping! And much thanks for that incredible project!
At this time i have to wait for some components (out of stock :-( )
Then i can test the board, fix some bugs, and publish on gihub.
Moderators: PCW, jmelson
Time to create page: 0.457 seconds
