7c81 and 2nd PWMgen problems
- llamatrails
31 Dec 2021 14:20 #230410
by llamatrails
7c81 and 2nd PWMgen problems was created by llamatrails
I'm trying to configure the 2nd PWMgen on my 7c81. I used pncconf to configure it, and changed the appropriate lines to run on the Raspberry Pi.
When I start linuxcnc, it errors out with "./7c81.hal:32: parameter or pin 'hm2_7c81.0.gpio.020.is_output' not found".
I can start linuxcnc if I comment out the 2nd PWMgen pin settings:
If I comment out the 1st PWMgen pin settings, I get the same error, even though the only difference is the gpio pin number, which the attached linuxcnc.report file shows as configured. Also attached is the 7c81.hal file, as generated by pncconf with the HMOT changed.
What am I missing?
TIA, Rick
# --- SPINDLE-ENABLE ---
setp [HMOT](CARD0).gpio.020.is_output true
net spindle-enable => [HMOT](CARD0).gpio.020.outIf I comment out the 1st PWMgen pin settings, I get the same error, even though the only difference is the gpio pin number, which the attached linuxcnc.report file shows as configured. Also attached is the 7c81.hal file, as generated by pncconf with the HMOT changed.
What am I missing?
TIA, Rick
- Thank you received: 5337
31 Dec 2021 14:38 - 31 Dec 2021 15:36 #230412
Replied by PCW on topic 7c81 and 2nd PWMgen problems
You are trying to use a PWM pin as GPIO, that is,
GPIO.020 is a PWM output if PWMGen 1 is enabled so
not available for GPIO output use:
hm2/hm2_7c81.0: IO Pin 020 (P2-02/DB25-14): PWMGen #1, pin Out0 (PWM or Up) (Output)
(if your bitfile is not what pncconf expects it will not know
that GPIO.020 is unavailable for output use, so you need
to setup and connect GPIO by editing the hal file)
Last edit: 31 Dec 2021 15:36 by PCW. Reason: clarify
- llamatrails
31 Dec 2021 15:55 - 31 Dec 2021 16:18 #230415
by llamatrails
Replied by llamatrails on topic 7c81 and 2nd PWMgen problems
I am trying to use pin 020 as a spindle PWM output. My 1st spindle on pin 007 works perfectly.
All I have to go by is what pncconf generated for me as in the linuxcnc.report that I attached shows.
Why didn't it squawk on the PWMGen 0 which is configured exactly the same on pin 007, as a GPIO out?
My bitfile is for the dual G540 configuration, pncconf is told it is a 5i25. Attached is the mesaflash readhmid output.
How should I change the [HMOT](CARD0).gpio.020.out ?
Would it be [HMOT](CARD0).pwm.020.out or something else? I haven't been able to find docs for this.
Thanks again, Rick
Thanks again, Rick
Last edit: 31 Dec 2021 16:18 by llamatrails. Reason: clarify
31 Dec 2021 16:25 - 31 Dec 2021 16:28 #230418
When you enable PWMgen 1 GPIO.020 is PWM output
and cannot be used as a general purpose output
Your hal file is trying to use GPIO.020 as a general; purpose
spindle enable output::
But this conflicts with GPIO.020's use as a PWM output.
(if PWM 1 is enabled in the hal file)
The 7C81 has different GPIO pin mappings than a
5I25 so as I said you need to see what GPIO connects
to which DB25 pins and chose appropriate GPIO
numbers
PWM 0 has no issues because you are using GPIO.007 for spindle
enable and GPIO.007 (DB-25 pin 17) is not used for anything other
than GPIO.
If you wanted to use the same DB25 pin for the second spindle enable,
you would use GPIO.026 which is DB25 pin 17 on P2
numbers
than GPIO.
Last edit: 31 Dec 2021 16:28 by PCW.
- llamatrails
31 Dec 2021 17:15 #230421
by llamatrails
Thanks again, Happy New Year !
Time to create page: 1.546 seconds
