Allen Bradley Ultra 100/200 servo drive software
- Henk
- Thank you received: 92
07 Feb 2022 04:13 #234222
by Henk
Allen Bradley Ultra 100/200 servo drive software was created by Henk
Hi. I am retrofitting a machine fitted with the above drives.
Downloaded the manuals for them and they are capable of analog velocity command, and it appears to have meen the way they were used in the past with the previous control.
However, these drives are tuned and set up using old software from AB called Ultra Master. Connects through a serial interface to the drive. I cannot find a copy of this software to download anywhere.
Does someone perhaps have a copy of the software or more detail of the serial commands to set the parameters on the drive?
ThanksHenk
ThanksHenk
28 Feb 2022 22:35 #236047
Replied by andypugh on topic Allen Bradley Ultra 100/200 servo drive software
If they were previously tuned for analogue control, then you probably don't need the software, they should already be tuned. Or has the setup been lost?
- JmParts
28 Feb 2022 22:53 #236055
by JmParts
Replied by JmParts on topic Allen Bradley Ultra 100/200 servo drive software
here's a copy of the ab software.
drive.google.com/file/d/1_GpnlRENPw4xSzI...jLh/view?usp=sharing
you need to use windows xp or older to run it. Worked great for my sub spindle lathe retrofit.
- Henk
01 Mar 2022 05:18 #236080
by Henk
Replied by Henk on topic Allen Bradley Ultra 100/200 servo drive software
Thanks Andy, The drives were in fact correctly set up from the previous application, so i had no problems. All the other IO were default as per the manual. I had no issues tuning the position loop.
Thank you also JMParts for the software.
Henk
Henk
- rvtran
02 Mar 2023 21:01 #265740
by rvtran
Replied by rvtran on topic Allen Bradley Ultra 100/200 servo drive software
Dear JM: You saved my life. Our machine has been down for almost 20 days because we do not have this software. AB do not sell it anymore.
Thank you very very much.
- dg0144
07 Apr 2023 16:47 #268531
by dg0144
Replied by dg0144 on topic Allen Bradley Ultra 100/200 servo drive software
I downloaded from this link from 2022. the files will not extract.
Can you please create a new link for software?
I need software to connect to ultra 100 drive.
thanks
Dave Gross
thanks
Dave Gross
- GiddsV
10 Dec 2024 07:41 #316379
by GiddsV
Replied by GiddsV on topic Allen Bradley Ultra 100/200 servo drive software
I registered just to say thank you for the software JMParts.
- ncysys
15 Jan 2025 21:47 #319053
by ncysys
Replied by ncysys on topic Allen Bradley Ultra 100/200 servo drive software
Hi
I too downloaded the zip file on Jan. 2025, but it didn't extract correctly also
Please check the files and provide a new link to the repaired files.
- ncysys
15 Jan 2025 21:56 #319055
by ncysys
I used 7-zip application to open and extract the files to the computer.
Thanks for providing the files.
Time to create page: 0.119 seconds
