Encoder Help with Mesa 7i96
17 Feb 2022 09:57 #235112 by tommylight
Replied by tommylight on topic Encoder Help with Mesa 7i96
Do you have everything grounded properly?
17 Feb 2022 14:47 #235139 by kbec
Replied by kbec on topic Encoder Help with Mesa 7i96
I think that is my problem. The encoder is to a 24v supply, and the board is 5v. I am fairly certain I can tie the grounds into one another, once I do that I will test again.
17 Feb 2022 14:52 #235140 by tommylight
You can not use a 24V encoder on a board with 5V inputs, that will for sure fry the inputs.
In such cases use of voltage dividers on the encoder outputs is required.
17 Feb 2022 15:24 #235145 by kbec
I see the encoder has a ground pin, I am going to try and hook that to my 24v ground. I am thinking that is the issue.
17 Feb 2022 15:28 #235146 by kbec
The encoder itself is hooked to 24v power supply. I have the output down to the proper voltage, it is just now my ground is not tied in correctly.
17 Feb 2022 17:12 #235147 by jmelson
Replied by jmelson on topic Encoder Help with Mesa 7i96
Yes, if the signals go to inputs that have a different ground reference, you MUST tie the grounds together.
Jon
 [/quote]
17 Feb 2022 18:10 #235154 by kbec
I fixed it by wiring the ground to the pin on the board for encoder ground. Now I am getting signals and they are off, but I am seeing a speed show up and the A,B and index pins changing.
Thanks to all of you for your help.
Moderators: PCW, jmelson
Time to create page: 0.119 seconds
