Theoretical - Jitter from MESA Field I/Os
- mydani
- Banned
- Thank you received: 9
20 Feb 2022 12:42 #235406
by mydani
Theoretical - Jitter from MESA Field I/Os was created by mydani
Hi guys,
maybe someone thought about this before.
E.g. using a mesa card with a spindle encoder in a lathe configuration (use case: threading) - typically it's connected to the FPGA.
What would happen if the index-signal would come from a field io instead?
Imho the field io is not connected directly with the fpga but via serial communication, so I'd expect some latency btw. state change and the info arriving at the fpga. In addition I could think of some jitter coming from the implementation, depending on how it's is implemented.
Am I right? Didn't have time today to look deeper into the VHDL, but maybe you can help me find some sleep before I have to open the sources...
Regards,
Daniel
Regards,
Daniel
- Thank you received: 5337
20 Feb 2022 13:22 #235413
Replied by PCW on topic Theoretical - Jitter from MESA Field I/Os
With Mesa cards, currently you cannot source an index signal from anywhere but the
FPGA encoder counter index input (because there is a intimate relationship between
the A,B and Index signals)
- mydani
- Banned
20 Feb 2022 14:51 #235429
by mydani
Replied by mydani on topic Theoretical - Jitter from MESA Field I/Os
Ok maybe bad example - it’s more about the delays and possible jitter of the field iOS. I guess it will be a multiple times smaller than typical servo thread timers, so it does not matter…
Time to create page: 0.897 seconds
