7i96 Bitfile Request
- thadwald
- Thank you received: 10
14 May 2022 16:31 - 14 May 2022 16:38 #242960
by thadwald
7i96 Bitfile Request was created by thadwald
I need a to interface the following on the P1 connector of the Mesa 7i96:
- 4 mpg quadrature encoders. These are the small thumbwheel type. no index pin required
- 4 inputs--each encoder has a button
- 1 step generator
- 1 high speed counter
Can anyone instruct me on how to set this up?
Or maybe point me to a working bitfile
Last edit: 14 May 2022 16:38 by thadwald.
The following user(s) said Thank You: Masiwood123
- Thank you received: 5334
14 May 2022 17:10 #242961
Replied by PCW on topic 7i96 Bitfile Request
Is the high speed counter a full ( A,B,Z ) encoder or just 1 input?
- thadwald
14 May 2022 17:54 #242968
by thadwald
Replied by thadwald on topic 7i96 Bitfile Request
Just one input for reading a v/f converter. The stepgen also needs only one output, as I’m only using it to clock the v/f chip.
14 May 2022 18:55 #242970
- thadwald
15 May 2022 02:01 #242997
by thadwald
Thank you!
- thadwald
25 Oct 2022 03:54 #254987
by thadwald
Could I get this configuration for the 7i96S?
25 Oct 2022 19:17 #255055
I will take a look at this sometime this week.
Note that the 7I96S normally has an
INM on the isolated inputs so if that's
left alone, the P1 INM/MPG pins will be
numbered differently (on inm.01 instead of inm00)
26 Oct 2022 01:40 #255069
7I96S config that matches the 7i96_p1inmspd config except for
different numbering of the MPGs
- thadwald
26 Oct 2022 04:26 #255075
by thadwald
Much obliged, sir!
Time to create page: 0.106 seconds
