7I76 output issue
4 years 3 months ago #247346 by 42walrustitan
I am hooking up a 7i76 card to my machine, and everything is working so far.  My machine is a CNC router that uses a hand held router as its spindle.  To control the spindle (Turn it on and off) it uses a GPIO controlled relay.  My problem is that I can not get the spindle on controls to operate the GPIO pins on the 7i76.  I am a total novice to this so any help would be appreciated.  Thanks
4 years 3 months ago #247349 by spumco
Replied by spumco on topic 7I76 output issue
Post your INI and HAL files so we can take a look at your configuration.
Have you used halshow yet?
4 years 3 months ago #247419 by 42walrustitan
Replied by 42walrustitan on topic 7I76 output issue
File Name: K2_Home_2.hal
File Size:9.89 KB
File Name: K2_Home_2.ini
File Size:3.95 KB
I have used hal meter and can determine that the signal for spindle enable is on
4 years 3 months ago #247420 by PCW
Replied by PCW on topic 7I76 output issue
There is nothing connecting motion-spindle-on to any
hardware output in the hal file
Normally this would connect to hm2_5i25.0.7i76.0.0.spinena
(and the 7I76 Spindle ENA+, ENA- output would be activated when true)
4 years 3 months ago #247423 by 42walrustitan
How would I resolve this issue.
4 years 3 months ago #247428 by PCW
It might be that you did not setup the spindle in pncconf?
I get these connections if I try:
# ---digital potentiometer output signals/setup---
setp [HMOT](CARD0).7i76.0.0.spinout-minlim [SPINDLE_0]OUTPUT_MIN_LIMIT
setp [HMOT](CARD0).7i76.0.0.spinout-maxlim [SPINDLE_0]OUTPUT_MAX_LIMIT
setp [HMOT](CARD0).7i76.0.0.spinout-scalemax [SPINDLE_0]OUTPUT_SCALE
net spindle-output => [HMOT](CARD0).7i76.0.0.spinout
net spindle-enable => [HMOT](CARD0).7i76.0.0.spinena
net spindle-ccw => [HMOT](CARD0).7i76.0.0.spindir
Moderators: PCW, jmelson
Time to create page: 0.078 seconds
