Adding 3rd MPG to 7i84
- tightmopedman9
- Thank you received: 8
22 Jul 2022 16:41 #248052
by tightmopedman9
Adding 3rd MPG to 7i84 was created by tightmopedman9
Is there any 'elegant' solution to adding more than two MPG inputs to a 7i84?
I'm already using the two built in encoder/MPG inputs, but would like to interface one more 5v MPG. The only solution I've come up with so far is a wcomp for the MPG outputs, and tying these outputs to encoder.N.phase-A/B.
- Thank you received: 5326
22 Jul 2022 17:14 #248054
Replied by PCW on topic Adding 3rd MPG to 7i84
I think the limit is the sserial packet size but I guess a variant could be made that drops
some data (or uses the new expanded sserialb)
- tightmopedman9
22 Jul 2022 20:53 #248071
by tightmopedman9
Replied by tightmopedman9 on topic Adding 3rd MPG to 7i84
Are you saying that it is possible to add additional encoders to the 7i84 by modifying the firmware? I assumed that the encoder limit was hardware based, not software.
I am only using 4 outputs, so I could lose some outputs, if that meant I could pick up an additional encoder.
29 Jul 2022 11:55 #248613
Replied by andypugh on topic Adding 3rd MPG to 7i84
What is the 7i84 plugged in to? Does that have a spare smart-serial port for a 7i73 (for example)
Also, don't discount the possibility of using GPIO pins and the software encoder counter. It _will_ miss counts if you wind at faster than 1000 c/s but that is 600 rpm for a 100-count MPG. At that speed of hand-twiddling I doubt that you would notice...
- tightmopedman9
31 Jul 2022 20:13 - 31 Jul 2022 20:13 #248750
by tightmopedman9
The encoder is for a 20ppr MPG knob for spindle speed override.
The 7i84 is connected to a 7i77, which does have a spare encoder input. I could use that input, but the knob is already wired to the 7i84 and I don't want to add additional wires from the control cabinet to the main enclosure.
I have 24v for the 7i84's field power supply, but the MPG is 5v. The only solution I've come up with is connecting the MPG to an analog input on the 7i84, and then in HAL passing the signal to a WCOMP and then to the software encoder. I was just wondering if there was a more elegant solution.
Last edit: 31 Jul 2022 20:13 by tightmopedman9.
31 Jul 2022 21:19 #248756
There is 7I84 firmware (7I84ET.BIN) that allows you to set the external thresholds
of the A and B inputs from LinuxCNC, that might simplify the software encoder a bit
- Online
- Thank you received: 7479
31 Jul 2022 21:30 #248758
Thank you.
Replied by tommylight on topic Adding 3rd MPG to 7i84
Nice to know, i have 2 of 7i84 still waiting for some love ... or time.There is 7I84 firmware (7I84ET.BIN) that allows you to set the external thresholds
Thank you.
Time to create page: 1.119 seconds
