PnCconf and Mesa 7i33
- Roguish
- Thank you received: 31
02 Aug 2022 14:27 #248842
by Roguish
Replied by Roguish on topic PnCconf and Mesa 7i33
doh. yes, I stated backwards.
you are correct.
It's 170 rpm/volt.
(just checked to be sure....)
thanks for the sanity check.
you are correct.
It's 170 rpm/volt.
- Thank you received: 1477
03 Aug 2022 16:00 #248942
Replied by Todd Zuercher on topic PnCconf and Mesa 7i33
What do the encoder's A and B signals look like in Halscope (at lower speeds where Halscope can actually read them)? Hal scope should be able to view those inputs as gpio at speeds where the pulses are less than 1kHz. I've seen some problems with encoder signal integrity when the drive is loaded, but clean when the drive isn't working. (But that wasn't with Mesa hardware or differential encoder signals.)
This does sound like an encoder configuration/wiring issue.
The following user(s) said Thank You: Roguish
- Roguish
04 Aug 2022 20:34 #249066
by Roguish
right now the A channel looks pretty good. B looks sporadic. I will be checking soon. just had some minor work on my knee, so i'm moving pretty slowly....
I'm going to be using double shielded wiring. each twisted pair shielded, and an overall shield,
Also looking into ferrites. Do you know anything about them? especially for encoder lines......
Time to create page: 0.207 seconds
