LED control through 7i96S board
- vkhargwanshi
- Thank you received: 6
02 Aug 2022 11:31 #248830
by vkhargwanshi
LED control through 7i96S board was created by vkhargwanshi
I am trying to switch on and off a simple LED to test how IO control works.
To check LED, I connected to 5v, it was working.
I presume that SSR OUTPUT can be used for the same.
I configured through PncConf the SSR output 3 to have as output pin.
I could see the entry in HAL file as
net dout-00 => hm2_7i96s.0.ssr.00.out-03
net dout-00 <= motion.digital-out-00
Now I though I can use M62-64 commands to control this pin with value of P as 03. But it doesn't seems to be working.
Then I checked in HALSHOW, I observed, except this pin, its allowing me to set and clear.
I am now clueless, looks like I am making some basic mistake, but unable to understand. Looking forward for the help.
The following user(s) said Thank You: behai
- phillc54
- Thank you received: 2100
02 Aug 2022 11:58 #248831
by phillc54
Replied by phillc54 on topic LED control through 7i96S board
motion.digital-out-00 would require P0
02 Aug 2022 22:30 #248874
Replied by andypugh on topic LED control through 7i96S board
The SSR outputs are switches, how do you have it wired?
- vkhargwanshi
03 Aug 2022 01:52 #248892
by vkhargwanshi
Replied by vkhargwanshi on topic LED control through 7i96S board
I am basically from software background and have little knowledge about electronics. I thought I can use it as simple GPIO out pin as mentioned in manual page.
I thought to use LED of a 5V relay to check if logic is working. Basically I need to connect a 12 V solenoid valve with 5V relay.
I am expecting that IN pin of relay can be controlled using GPIO out pin of 7i96S, which are numbered from 13-20.
So when I have following in HAL file, so I believed I should be able to control Pin 20 using command M64 P00. In HAL show, its showing me correct as per expectation. But the relay is not working.
- Thank you received: 5328
03 Aug 2022 03:51 - 03 Aug 2022 03:52 #248897
Replied by PCW on topic LED control through 7i96S board
As andypugh said, the SSR outputs are switches, the do not supply voltage by
themselves.
When hm2_7i96s.0.ssr.00.out-03 is true, 7I96S TB3 pins 19 and 20 are connected, and
when hm2_7i96s.0.ssr.00.out-03 is false, 7I96S TB3 pins 19 and 20 are disconnected.
There is no voltage output from these pins. If you want to drive a 5V load, you would
connect:
+5V ==> TB3 pin 20 (Out3+)
TB3 pin 19 (Out3-) ==> 5V Relay+
5V Relay- ==> GND
themselves.
connect:
5V Relay- ==> GND
Last edit: 03 Aug 2022 03:52 by PCW.
The following user(s) said Thank You: vkhargwanshi, behai
- vkhargwanshi
03 Aug 2022 04:10 #248898
by vkhargwanshi
Thanks a lot PCW, as always your answers are crisp and clear...
I will try this and get back in case I get stuck.
Time to create page: 0.087 seconds
