No 7C81 board found
- Me3
26 Aug 2022 03:35 #250485
by Me3
No 7C81 board found was created by Me3
First try at setting up a Mesa card as well as a newby to Linuxcnc. Oops!
I mistakenly flashed my 7c81 with 7c81epp.bit ,( thinking it would be the best match to my existing Mach3 parallel port)
Now my board responds like this and I don't know how to get it back
sudo mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --readhmid
unable to set bpw32, fallback to bpw8
Unexpected cookie at 0100..0110:
00000000 00000000 00000000
No 7C81 board found
Here is the complete mess I've made, can some kind soul help me put the genie back in the bottle?
pi@raspberrypi:~/hostmot2 $ sudo mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --readhmid
Configuration Name: HOSTMOT2
BoardName : MESA7C81
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 3
Width of one I/O port: 19
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 1 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: StepGen
There are 10 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: PWM
There are 3 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P1+Serial
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
0 0 IOPort PWM 0 PWM (Out)
0 1 IOPort None
0 2 IOPort StepGen 0 Step/Table1 (Out)
0 3 IOPort None
0 4 IOPort StepGen 0 Dir/Table2 (Out)
0 5 IOPort None
0 6 IOPort StepGen 1 Step/Table1 (Out)
0 7 IOPort None
0 8 IOPort StepGen 1 Dir/Table2 (Out)
0 9 IOPort StepGen 2 Step/Table1 (Out)
0 10 IOPort StepGen 2 Dir/Table2 (Out)
0 11 IOPort StepGen 3 Step/Table1 (Out)
0 12 IOPort StepGen 3 Dir/Table2 (Out)
0 13 IOPort None
0 14 IOPort QCount 0 Quad-A (In)
0 15 IOPort QCount 0 Quad-B (In)
0 16 IOPort QCount 0 Quad-IDX (In)
0 17 IOPort SSerial 0 TXData0 (Out)
0 18 IOPort SSerial 0 TXData1 (Out)
IO Connections for P2+Serial
0 19 IOPort PWM 1 PWM (Out)
0 20 IOPort None
0 21 IOPort StepGen 4 Step/Table1 (Out)
0 22 IOPort None
0 23 IOPort StepGen 4 Dir/Table2 (Out)
0 24 IOPort None
0 25 IOPort StepGen 5 Step/Table1 (Out)
0 26 IOPort None
0 27 IOPort StepGen 5 Dir/Table2 (Out)
0 28 IOPort StepGen 6 Step/Table1 (Out)
0 29 IOPort StepGen 6 Dir/Table2 (Out)
0 30 IOPort None
0 31 IOPort None
0 32 IOPort None
0 33 IOPort None
0 34 IOPort None
0 35 IOPort None
0 36 IOPort SSerial 0 TXEn0 (Out)
0 37 IOPort SSerial 0 TXEn1 (Out)
IO Connections for P7+Serial
0 38 IOPort PWM 2 PWM (Out)
0 39 IOPort None
0 40 IOPort StepGen 7 Step/Table1 (Out)
0 41 IOPort None
0 42 IOPort StepGen 7 Dir/Table2 (Out)
0 43 IOPort None
0 44 IOPort StepGen 8 Step/Table1 (Out)
0 45 IOPort None
0 46 IOPort StepGen 8 Dir/Table2 (Out)
0 47 IOPort StepGen 9 Step/Table1 (Out)
0 48 IOPort StepGen 9 Dir/Table2 (Out)
0 49 IOPort None
0 50 IOPort None
0 51 IOPort None
0 52 IOPort None
0 53 IOPort None
0 54 IOPort None
0 55 IOPort SSerial 0 RXData0 (In)
0 56 IOPort SSerial 0 RXData1 (In)
pi@raspberrypi:~/hostmot2 $ ls
7c81_5abobx2d.bit 7c81_7i77x1_7i76x1d.pin 7c81_dmmbobx2d.bit
7c81_5abobx2d.pin 7c81_7i77x2d.bit 7c81epp.bit
7c81_5abobx3d.bit 7c81_7i77x2d.pin 7c81_fallback.bit
7c81_5abobx3d.pin 7c81_7i78x2d.bit 7c81_g540x2d.bit
7c81_7i76x2_7i89.bit 7c81_7i85sx2d.bit 7c81_g540x2d.pin
7c81_7i76x2d.bit 7c81_7i88ssx1d.bit 7c81_mx3660x2d.bit
7c81_7i76x2d.pin 7c81_c11gx2d.bit 7c81_mx3660x2d.pin
7c81_7i77x1_7i76x1d.bit 7c81_c11gx2d.pin source
pi@raspberrypi:~/hostmot2 $ sudo mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --verbose --write 7c81epp.bit
Checking file... OK
File type: BIT file
Design name: TopEPPSHostMot2.ncd;UserID=0xFFFFFFFF
Part name: 6slx9tqg144
Design date: 2018/10/10
Design time: 16:07:30
Config Length: 340604
Error: BootSector is invalid
pi@raspberrypi:~/hostmot2 $ sudo mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --verbose --fix-boot-block --write 7c81epp.bit
Checking file... OK
File type: BIT file
Erasing sector 0 for boot block
BootBlock installed
EEPROM sectors to write: 6, max sectors in area: 8
Erasing EEPROM sectors starting from 0x80000...
|EEEEEE
Erasing time: 1.35 seconds
Programming EEPROM sectors starting from 0x80000...
|WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
Programming time: 25.47 seconds
Board configuration updated successfully.
Checking file... OK
File type: BIT file
Boot sector OK
Verifying EEPROM sectors starting from 0x80000...
|VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
Verification time: 36.02 seconds
Board configuration verified successfully.
You must power cycle the hardware or use the --reload command to load a new firmware.
pi@raspberrypi:~/hostmot2 $ sudo mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --verbose --reload
Waiting for FPGA configuration...OK
pi@raspberrypi:~/hostmot2 $ sudo mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --verbose --verify 7c81epp.bit
No 7C81 board found
No 7C81 board found
pi@raspberrypi:~/hostmot2 $ sudo poweroff
Connection to raspberrypi.local closed by remote host.
Connection to raspberrypi.local closed.
user@user-B450-AORUS-M:~$ ssh -X This email address is being protected from spambots. You need JavaScript enabled to view it.
pi@raspberrypi.local's password:
Linux raspberrypi 4.19.71-rt24-v7l+ #1 SMP PREEMPT RT Fri Jan 1 21:15:16 GMT 2021 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Aug 25 22:13:17 2022
pi@raspberrypi:~ $ sudo mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --readhmid
No 7C81 board found
pi@raspberrypi:~ $ halrun
halcmd: loadrt hostmot2
Note: Using POSIX realtime
halcmd: loadrt hm2_rpspi
hm2_rpspi: SPI0/CE0 Invalid cookie, read: 00000000 00000000 00000000, expected: 55aacafe 54534f48 32544f4d
hm2_rpspi: SPI0/CE0 No drive seen on MISO line (kept at pull-down level). No board connected or bad connection?
hm2_rpspi: rtapi_app_main: No such device (-19)
<stdin>:2: waitpid failed /usr/bin/rtapi_app hm2_rpspi
<stdin>:2: /usr/bin/rtapi_app exited without becoming ready
<stdin>:2: insmod for hm2_rpspi failed, returned -1
halcmd: show pin
Component Pins:
Owner Type Dir Value Name
halcmd: exit
hm2_rpspi: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
hm2: unloading
<commandline>:0: unloadrt failed
No 7C81 board found
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: DPLL
Version: 0
Registers: 7
BaseAddress: 7000
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: PWM
Version: 0
Registers: 5
BaseAddress: 4100
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
0 1 IOPort None
0 3 IOPort None
0 5 IOPort None
0 7 IOPort None
0 13 IOPort None
0 20 IOPort None
0 22 IOPort None
0 24 IOPort None
0 26 IOPort None
0 30 IOPort None
0 31 IOPort None
0 32 IOPort None
0 33 IOPort None
0 34 IOPort None
0 35 IOPort None
0 39 IOPort None
0 41 IOPort None
0 43 IOPort None
0 45 IOPort None
0 49 IOPort None
0 50 IOPort None
0 51 IOPort None
0 52 IOPort None
0 53 IOPort None
0 54 IOPort None
Checking file... OK
File type: BIT file
Checking file... OK
File type: BIT file
BootBlock installed
|EEEEEE
Checking file... OK
File type: BIT file
Boot sector OK
No 7C81 board found
No 7C81 board found
No 7C81 board found
halcmd: show pin
Component Pins:
halcmd: exit
hm2: unloading
- Thank you received: 7490
26 Aug 2022 09:07 #250496
Replied by tommylight on topic No 7C81 board found
Moved to "driver boards".
Looks like the board is still communicating, so better wait till PCW chimes in.
- Thank you received: 5334
26 Aug 2022 15:31 #250524
Replied by PCW on topic No 7C81 board found
Unless you have a JTAG cable, you likely have to send the card back
to Mesa to be reprogrammed.
- Me3
26 Aug 2022 16:22 #250530
by Me3
Replied by Me3 on topic No 7C81 board found
Thanks for you quick reply.
Lots of experience making cables.
Which software would I need to program it.
Do I need addittional hardware to use with the JTAG?
26 Aug 2022 16:34 - 26 Aug 2022 16:44 #250531
For JTAG, you would need a Xilinx Impact compatible JTAG programmer
(the parallel port based one is cheap and workable)
Impact can be downloaded from Xilinx not sure if it can be downloaded
separately from Webpack (which is enormous)
Another option is to make a EPP cable fro the 7C81
and reflash the card via EPP (needs a PC with a EPP
capable parallel port running Linux and a funny cable)
Another possible option is to disrupt the firmware loading
at power up so a CRC error is created, the FPGA loader will
then load the fallback configuration (which has a SPI interfce)
This would require say grounding the SPI flash's chips data out pin
very briefly at power up. If this is successful, you should get a blinking
/INIT light, indicating that the fallback configuration has been loaded.
Last edit: 26 Aug 2022 16:44 by PCW.
- Me3
26 Aug 2022 16:51 #250532
by Me3
Option 3 sounds simple. How do I identify the gata out pin required?
26 Aug 2022 17:00 #250533
Well its tricky because you need to disrupt the user
image load but not subsequent the fallback load.
Don't have the data sheet in front of me but it's the
SOP8 W25W16 or W25Q32 chip
- Me3
26 Aug 2022 18:52 #250541
by Me3
"Another option is to make a EPP cable fro the 7C81
capable parallel port running Linux and a funny cable)"
Can you give me details on this procedure?
By the way, thanks for all your help.
26 Aug 2022 20:05 #250543
You would need an adapter cable like this:
The run mesaflash from a PC with EPP port and
reflash the card with the desired SPI firmware
- Me3
26 Aug 2022 21:20 #250545
by Me3
Thank you PCW. Now I have three approaches to fix my mistake. I'll report back on which ways I try and my results.
Much better than mailing it back with the shipping charges being half the price of a new card.
A related question: what does the 7c81epp.bit file configure the board to do?
Time to create page: 0.289 seconds
