Mesa 7i96S
  • JT
  • JT's Avatar Topic Author
  • Administrator
  • Administrator
28 Aug 2022 12:32 #250614 by JT
Mesa 7i96S was created by JT
If your struggling with ethernet time out errors you may want to try 4.x kernel if using Debian. Also if you want to use your 7i96S with LinuxCNC 2.8 the instructions are here.
gnipsel.com/linuxcnc/debian-10.html
gnipsel.com/linuxcnc/debian-10-fix.html
gnipsel.com/linuxcnc/debian-10-emc.html
gnipsel.com/linuxcnc/debian-10-eth.html
JT
  • JT
  • Administrator
  • Administrator
28 Aug 2022 18:03 #250625 by JT
Replied by JT on topic Mesa 7i96S
Just got word that the latest deb released today supports the Mesa 7i96S.
linuxcnc_2.9.0~pre0+git20220827.f7d1c37ffd-1_source.changes ACCEPTED into unstable
Might take a day or two to actually show up after you do apt update.
JT
  • Moderator
  • Moderator
28 Aug 2022 20:07 #250644 by tommylight
Replied by tommylight on topic Mesa 7i96S
Oh good, two nights ago i checked it was still 20220404.
Need to update some links... :)
  • JT
  • Administrator
  • Administrator
29 Aug 2022 21:56 #250737 by JT
git20220827 has made it to 13 but not 12 yet.
packages.debian.org/search?searchon=names&keywords=linuxcnc
JT
01 Sep 2022 14:38 - 01 Sep 2022 15:11 #250926 by Masiwood123
Replied by Masiwood123 on topic Mesa 7i96S
will debian 11.4 (12 from your post I install) recognize it? I mean, will pnccfg give an option for mpg at the inputs (I need two independent mpg wheels) or do I have to do additional work afterwards in the hal? I'm still waiting for the card so I'll let you know, in mesact 7.1 I also couldn't manage to assign MPG functions to the inputs at first glance. Thanks a lot
Last edit: 01 Sep 2022 15:11 by Masiwood123.
  • JT
  • Administrator
  • Administrator
02 Sep 2022 12:08 #250994 by JT
I don't use pncconf so you would have to ask in that section about that tool.
JT
The following user(s) said Thank You: Masiwood123
02 Sep 2022 12:12 #250995 by Masiwood123
ok, the situation is the same in mesact, but I will see when the card arrives and when the system recognizes it, maybe it will change.
10 Oct 2022 15:23 #253891 by blazini36
Replied by blazini36 on topic Mesa 7i96S
A friend of mine maintains the 2.8 package in the AUR (for Arch based distros). I've been running the 2.8.2 from this for over a year. I was able to get it to build 2.8.4 with minor changes to the PKGBUILD. My friend should be updating the package shortly.
Glade-GTK2 also builds from the AUR without headaches. Everytime I have to redo this LinuxCNC system I always try to use Debian first (not sure why). I got LinuxCNC to build but I had to abandon Debian for other issues. I always find Debian to be more of a hassle than it's worth.
Not sure what the "official" word on LCNC on Arch is being a rolling distro but Arch in general (or it's more user-friendly offshoots) are much nicer to deal with than anything Debian based.
Moderators: PCW, jmelson
Time to create page: 0.142 seconds
