In your custom.hal this is the syntax for changing your contrast voltage:
setp lcd.00.contrast .45
.45 is what worked well for my LCD, but it can be any number from zero to one. Just open your HAL config and use the "test HAL command" input to change it until you find what works best for yours then toss it into your custom.hal
Hope that helps.
