7i85 GPIO
11 Sep 2022 23:51 #251710 by JacobRush
7i85 GPIO was created by JacobRush
I find myself needing some 5v inputs/outputs and I have several unused serial ports on my 7i85. I've tried:
loadrt hm2_eth board_ip="10.10.10.10" config="sserial_port_0=00XXX"
Thinking that would disable the unused serial ports, freeing them up for GPIO. I only need sserial 0 and 1.
But I don't see any additional GPIO pins available.
My setup is a 7i92 -> 7i85 -> 7I83/7i84
I show GPIO pins 0-33 regardless of sserial_port settings. I believe these represent pins on my 7i92? Speaking of... How do I find out how the GPIO pins map to physical pins?
11 Sep 2022 23:57 - 12 Sep 2022 00:00 #251711 by PCW
Replied by PCW on topic 7i85 GPIO
mesaflash --device 7i92 --addr 10.10.10.10 --dbname1 7i85 --readhmid
You will not see different GPIO if you did not have active sserial devices
on the enabled vs disabled channels (if no sserial device is found, the port pins will
revert to GPIO automatically)
Last edit: 12 Sep 2022 00:00 by PCW.
The following user(s) said Thank You: JacobRush
12 Sep 2022 00:40 #251715 by JacobRush
Replied by JacobRush on topic 7i85 GPIO
Ah, that makes sense.
I can't quite make sense of how the pins map to GPIO 0-33. Does the below output from mesaflash tell me?
For example I'd like to use TB1-20 as an input and TB1-21 as an output.
IO Connections for P2 -> 7I85
Pin#                  I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
TB1-19,20               0   IOPort       SSerial          0        RXData4         (In)
TB1-21,22               1   IOPort       SSerial          0        TXData4         (Out)
TB1-11,12               2   IOPort       SSerial          0        RXData3         (In)
TB1-13,14               3   IOPort       SSerial          0        TXData3         (Out)
TB1-3,4                 4   IOPort       SSerial          0        RXData2         (In)
TB1-5,6                 5   IOPort       SSerial          0        TXData2         (Out)
TB2-19,20               6   IOPort       SSerial          0        RXData1         (In)
TB2-21,22               7   IOPort       SSerial          0        TXData1         (Out)
TB2-11,12               8   IOPort       SSerial          0        RXData0         (In)
TB2-13,14               9   IOPort       SSerial          0        TXData0         (Out)
Internal-EncMux        10   IOPort       MuxedQCountSel   0        MuxSel0         (Out)
TB3-1,2,9,10           11   IOPort       MuxedQCount      0        MuxQ-A          (In)
TB3-4,5,12,13          12   IOPort       MuxedQCount      0        MuxQ-B          (In)
TB3-7,8,12,13          13   IOPort       MuxedQCount      0        MuxQ-IDX        (In)
TB3-17,18,TB2-1,2      14   IOPort       MuxedQCount      1        MuxQ-A          (In)
TB3-20,21,TB2-4,5      15   IOPort       MuxedQCount      1        MuxQ-B          (In)
TB3-23,24,TB2-7,8      16   IOPort       MuxedQCount      1        MuxQ-IDX        (In)
12 Sep 2022 01:20 - 12 Sep 2022 02:55 #251716 by PCW
The input and outputs are differential
For outputs you just choose the inverted or non-inverted pin (TB1 21 or 22)
Inputs are not so easy as these are differential and terminated
(with 120 Ohms across TB1 19,20). You can use these as 5V inputs
if you terminate one of the input pair with a stiff say 1.6V reference
and drive the other pin with a series resistor (say 470 Ohm)
Note that you can use a spare encoder input (say a unused index pin) as a 5V input
Last edit: 12 Sep 2022 02:55 by PCW.
Moderators: PCW, jmelson
Time to create page: 0.290 seconds
