Probably been asked, ! How do I install the mesa firmware files.
- M4MazakUser
- Thank you received: 7
15 Sep 2022 04:05 #251974
by M4MazakUser
Probably been asked, ! How do I install the mesa firmware files. was created by M4MazakUser
I just did an install, and can't find any mesa firmware on drive. Where do you get it/is there an easy way to install them.
- M4MazakUser
15 Sep 2022 04:30 #251975
by M4MazakUser
Replied by M4MazakUser on topic Probably been asked, ! How do I install the mesa firmware files.
I'm using debian unstable, and a 5i22 card (not much available) the directory where they should be- /lib/hm2 etc dosent exist.
- JPL
- Thank you received: 118
15 Sep 2022 06:12 #251978
by JPL
Replied by JPL on topic Probably been asked, ! How do I install the mesa firmware files.
There: store.mesanet.com/index.php?route=produc...ct_id=64&search=5i22
Click on the 'specification' tab then 'download support software'
- Thank you received: 4150
15 Sep 2022 07:52 #251979
Replied by rodw on topic Probably been asked, ! How do I install the mesa firmware files.
you need mesaflash to update the firmware. You can install with
sudo apt install mesaflash
- Thank you received: 7488
15 Sep 2022 10:38 #251984
Replied by tommylight on topic Probably been asked, ! How do I install the mesa firmware files.
Pretty sure Mesa 5i22 loads the firmware at boot time, so there is no flashing.
- M4MazakUser
15 Sep 2022 11:36 #251991
by M4MazakUser
I am just trying to run the example configs supplied with linuxcnc. The files from mesa aren't even named similar. (Case and there's a "b" and an "s" in two of the bin file names not sure which suits.
15 Sep 2022 11:39 #251992
Moved to "driver boards".
Off topic, do you have any schematics of that Mazak?
- M4MazakUser
15 Sep 2022 18:39 #252020
by M4MazakUser
The machine im currently doing up is a Chinese/fanuc lathe, it went 4metres underwater, so I'm rebuilding everything. It's actually quite well made. I rebuilt an old m4 around 13years ago, it drowned as well, but I don't work at that place. I put up lots of posts back when I did it.
Time to create page: 0.199 seconds
