LinuxCNC + CNC-Drive UC300ETH-5LPT ethernet motion controller?
- null
- Thank you received: 4
17 Sep 2022 16:08 #252176
by null
LinuxCNC + CNC-Drive UC300ETH-5LPT ethernet motion controller? was created by null
Determined to escape to open source cnc, can I bring my UC300ETH with me?
Had a bit of a look around but can't find definitive info - thanks for any opinions.
- Thank you received: 7463
17 Sep 2022 17:33 #252182
Replied by tommylight on topic LinuxCNC + CNC-Drive UC300ETH-5LPT ethernet motion controller?
Search for Remora, it is a developing project with lots of members involved and making progress daily.
Not sure if yours is supported yet, but pretty sure one of the 300 is being worked on.
The following user(s) said Thank You: null
- robertspark
- Thank you received: 216
17 Sep 2022 17:52 #252183
by robertspark
Replied by robertspark on topic LinuxCNC + CNC-Drive UC300ETH-5LPT ethernet motion controller?
no you won't be able to use the uc300eth.
- null
17 Sep 2022 18:48 #252193
by null
Replied by null on topic LinuxCNC + CNC-Drive UC300ETH-5LPT ethernet motion controller?
OK, thanks - time for a rethink
- GaryLa
17 Sep 2022 21:48 #252206
by GaryLa
Replied by GaryLa on topic LinuxCNC + CNC-Drive UC300ETH-5LPT ethernet motion controller?
Didn't they release support for Mach3?
If so, I would think LinuxCNC would be next.
- Thank you received: 4138
18 Sep 2022 06:20 #252239
Replied by rodw on topic LinuxCNC + CNC-Drive UC300ETH-5LPT ethernet motion controller?
UC300ETH is a motion controller, Linuxcnc is also a motion controller. You don't need 2 motion controllers. They are not compatible.Didn't they release support for Mach3?
- robertspark
18 Sep 2022 08:17 #252246
by robertspark
the UC motion controllers are (all) compatible with uccnc (that is their primary CNC software developed by cncdrive for their UC motion controllers), mach 3 and mach4
with mach 3 and mach4 they are only partially compatible. they don't offer threading on mach4 or synchronised lathe spindle functions.
cncdrive have provided an API for Windows, but I cannot see them opening up to linuxcnc.
the UC devices are motion controllers, data is buffered between the pc and the UC hardware device and all timing is done within the UC hardware device. the front end is essential blind to what is actually happening NOW as part of CNC motion because all timing functions are done within the UC hardware device.
linuxcnc won't like working with that approach.
I have a cupboard full of (expensive) CNC drive stuff, that is gathering dust. uc400eth, uc300eth, UB1, UD1, neuron lite thx mini THC and various other lot bobs. + 2x uccnc licences.
buy some Mesa hardware (or you can actually use some of the 3d printer hardware now) and learn linuxcnc. sure it's complex and confusing but once you get it it will begin to make sense. plus it works.
The following user(s) said Thank You: tommylight, rodw, null
18 Sep 2022 11:19 #252252
Plus there are no limits to what can be donebuy some Mesa hardware (or you can actually use some of the 3d printer hardware now) and learn linuxcnc. sure it's complex and confusing but once you get it it will begin to make sense. plus it works.
- GaryLa
18 Sep 2022 14:41 #252267
by GaryLa
When I saw they had support for Mach3, I assumed they had written a different firmware for the UC300 which allowed it to just be a breakout board.
- null
18 Sep 2022 15:18 #252268
by null
robertspark - thanks for the pointers, I'll look into Mesa.
Time to create page: 0.263 seconds
